Question about LG 42PX5D 42 in. Plasma HDTV
Connecting to PC
HI, Im trying to connect my pc to a 42PX5D LG plasma tv.... I have changed the settings on the TV to RGB/PC and connected the computer. When I start up the computer it Loaded okay, and displayed on the TV until it went to show the desktop, then the screen goes blank and I get an error stating "invaild format" Please help... Thanks Sarah
  • sarah britten Apr 15, 2007
    Thanks - works a treat!!! Kind Regards Sarah
    Brigadier General:
  • 6,966 Answers
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Posted on Apr 14, 2007
The manual recommends using a resolution of 1024x768 and a refresh rate of 60Hz when you connect a PC to this model. You've probably trid the correct resolution, but my guess is you need to change the refresh rate. - Mav (Australia)
Posted on Aug 24, 2007
SOURCE:
I have a lg plasma and im trying to connect it to my pc hooked up the vga in the comp and on the backside of my tv, have the audio and hooked it up to the audio, but when i change input i can see the pc on...
It sounds like you are using the wrong audio input jack, by chance are you using the audio cable with RED and WHITE RCA to mini stereo plug ?
If you look at the VGA port on the the TV, you will see a small mini phone jack (PC audio) close by, that will be for the sound input when TV is in PC mode.
Please verify for me.
Dec 31, 2010 | LG 42PX5D 42 in. Plasma HDTV
Colour probem
Try connecting any other device to the TV and check to confirm whether the issue is with the TV. Then, try resetting the TV to the factory settings. If the issue persists, try Power resetting the TV and check. If the issue still persists, the TV may require service.
Jul 26, 2010 | LG 42PX5D 42 in. Plasma HDTV
I'm trying to connect my desktop Dell (PC) to my 26LG30 tv. When I start it up, all appears to go as normal - and then it goes to "invalid format" on the screen. I've set the TV input to RGB-PC and...
Try to reinstall the video driver for the desktop. you can download the drivers from http://support.dell.com
Also flash the bios of the computer by download int the file from the above website.
and also try to change the resolution by connecting to a monitor and try connecting to the TV ..
Dec 26, 2009 | LG 26LG30 26 in. LCD TV
Connecting pc to lg 32 inche
you have not mention the model of lg 32"   what i suggest is lower the resolution of your hp pc tp 800 by 600  and gradualy increase the res to get the picture which matches the plasma hope this will solve your problem
Nov 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Connecting plasma tv to pc
You need to either connect to the TV the cord that your computer monitor would connect to or have a video card that supports S-Video and the appropriate cables S-Video and RCA audio out cables for either.
Then you must select the appropriate input on your TV, such as VGA or S-Video (and audio in.) .
Let us know how you make out.
Feb 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
My 37" LG cannot detect my Fijiutsu siemens L7320 laptop
need to go in to your laptop to see devises to enble laptop to tv
Jan 03, 2008 | LG 42PX5D 42 in. Plasma HDTV
Connecting PC to TV
You have to activate the external/dual monitor feature of your PC.  If it's a laptop, it's Fn + F? key and if your PC is a desktop you have to go to the Display Properties, Settings tab, Advance button.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Oct 15, 2007 | LG 42PX5D 42 in. Plasma HDTV
Trying to connect PC
pls see your other post.
Cheers.
Connecting to pc
in the menu screen you will see RGB DTV Highlight that setting and use the right arrow on the remote and you will come across RGB PC. Make sure that is selected and " back out " of the menus. Enjoy
Aug 30, 2006 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
598 people viewed this question
Steve Allison
Steve Allison
