Convergence Problem and Contrast Adjustment
I have been working on my daughter's rear projection TV convergence problem. Today I replaced the two convergence amplifier IC's, which fixed the initial problem of the blue being non-adjustable for targets 3, 6 and 9. Those dial in just fine now, as do all the other Convergence Adjustment 2 menu targets. However, on Convergence Adjustment 1 (white target in the center of the screen) the blue adjusts through about an inch range, although I cannot bring it far enough left to converge with the white target. I am out about 1/4'' to the right on the blue at the full left limit. The green is adjusted to align with the calibration marks on the screen frame, and the red convergence adjusts just fine. Is there a physical adjustment required to the blue CRT, or a sub-menu (serviceman adjustment) to bias that blue CRT centering further to the left? Also, on the Picture menu there is no Contrast adjustment. Where and/or how do I adjust contrast? The picture is plenty bright, but the contrast is too high and much of the fine detail is lost. Thanks in advance for any assistance.
  • 1 more comment
  • Dick Dec 25, 2008
    For some reason, the make and model didn't post. The TV in question is a Panasonic Rear Projection PT-53WX52F.
  • Dick Dec 25, 2008
    No, I didn't check the resistors, but none showed any sign of discoloration or heat stress. The IC replacement came off without a hitch. The defectives came out on the first try, and the new ones dropped right in. I'll check techlore for your manual. Thanks for the tip. Do you have any suggestions on the contrast adjustment? Is that something that is accessable through the Service Menu? Thanks -- ****
  • Dick Dec 25, 2008
    I just checked the manual at techlore.com and I get a "File Damaged and Cannot Be Repaired" message in Adobe Reader at the end of the download. I downloaded another manual and it went fine. FYI.
    Sergeant:
  • 233 Answers
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
Posted on Dec 25, 2008
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
When you turn the tv on you have a green tint to the picture and the red bleeds like it's glowing
Not able to do auto or manual convergence adjustment.The tv convergence board is dead.The tv convergence board,must be replacing 2 STK convergence ICS and some or all of it resistors too.To fix the convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-$350
Jun 10, 2011 | Philips 60PP9202 60" Rear Projection...
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
Blue gun adjustment does not move blue line in menu convergence function. Any way to adjust or fix?
No.Fix.Tv have dead parts on the tv convergence board.Tv colors lines R,G,B mis alignment,can't move any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead on the tv convergence board.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Toshiba 61H70 61" Rear Projection...
The convergance adjustment is not working. Some of the cross hairs will not move.
The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.The parts on the convergence board,must be replaced to solved the tv convergencce picture problems.The shop,will $300-350 for parts and labors.
Oct 17, 2010 | Philips 60PP9202 60" Rear Projection...
Samsung Tantus projection TV 40 inches. the problem is that when it has worked for 5 minutes the text and picture is having a trace line that looks like a convergence problem in conventional CRT tv. any...
U have the early warning problems of the convergence problems.Do the manual or auto convergence adjustment until,u can't do it anymore.Replaced all the parts,that make the convergence board to work.
Jun 22, 2010 | Apex Digital GB4308 43" Rear Projection...
Convergence is off and wont adjust with remote control adjustment
Convergence control will disappear / inactive in TV menu when Convergence out section got failure.
Please replace convergence out board in TV to solve this problem.
Is it Samsung HC-N473W model?
Thanks.
Nov 02, 2009 | Samsung HCN473W 47" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
492 people viewed this question
Top Televison & Video Experts
