Question about Dewalt Drills
Drill causes my Battary to smoke & Burn out
Drill runs fine, but when left to sit it causes Battary to smoke & unable to hold Charge.
  • 2,176 Answers
Do you have more than one battery and if so do they both do this? It sounds like the batery has shorted out or possibly the switch is malfunctioning and creating the short either way I would not try and recharge a battery that has these symptoms. I actually had a NiCad battery catch on fire when I charged it not knowing the history of battery. There are repair centers that usually won't charge you to check batterys/drill or maybe a minimal fee but it is cheaper than replacing batterys constantly. Good luck. Dave
Posted on Dec 25, 2008
E 280 w211 runs fine. Recorded 59.3 mpg on long run at 65mph in cruise. If left on tickover for a few mins ie junction or traffic lights blue smoke from exhaust. Car does not burn oil
Bad valve stem seals will cause smoke under these circumstances. It will get worse. The reason this happens is because the higher engine vacuum present in traffic will pull oil past the worn valve stem seals into the cylinder. When you accelerate again, the engine burns this small amount of oil causing the smoke.
Sep 15, 2016 | Cars & Trucks
Why does fire burn u
Because its hot. Not only will fire burn you but any material or object that is hot can burn you or cause scorching or smoke. An electrical charge can burn you. Leaning against a hot car in the heat of the sun can burn you. Very hot water can burn you. A iron left on can burn you. A stove top burner or oven can burn you. If it's hot, IT BURNS! !
Mar 25, 2015 | Cars & Trucks
The idle on the generator went from low to very high and smog came out my magnetic drill now turns very slow what can I do
It sounds like the governor on the generator is not working or something is holding the throttle wide open. That would cause the generator to produce too much voltage for the drill. The armature in the drill has likely been toasted. That's what caused the smoke. The drill may have a short in the windings and some of the plates may even have been melted off the commutator.
It sounds to me like the drill may need its armature rebuilt or the drill may need a new armature. The outer windings may be affected as well. Just before the drill started smoking, I would guess the drill was running faster than normal.
Mar 17, 2015 | Electrical Supplies
My 18v worx drill batterywont hold a charge
sounds like the battery is kaput you can only charge a certain number of times or the battery has developed a memory which causes it to fail, usually caused by not fully discharging it in use and putting it back on charge when the battery still has plenty of power left. the cycle is fully discharge then recharge or check your user manual on battery
regards pete
Jul 02, 2014 | Drills
I have a 2005 Polaris Sportsman 800 EFI and it suddenly started running rough and started smoking. .
If gasoline is left sitting for a while (2-3 months) it attracts water, which could cause the "smoke" and rough running engine.
Unless it is a 2 stroke engine, no oil should be coming out the exhaust. Hold a clean rag or a bunch of paper towels at the exhaust opening BE CAREFUL NOT TO BURN YOURSELF and than check if, whatever the rag or paper towels catch is oily. If it is a 4 stroke engine, and oil is the exhaust fumes, a seal inside the engine is gone and has to be replaced.
Jan 06, 2014 | ATVs
Smoke come from motor and now drill hardly moves .is new motor required or brushes
You will rarely get smoke from the brushes on electric tools. Smoke is usually a result of either the armature or field coils getting hot enough to melt or burn the varnish insulation off the wire which results in a loss of or no power because of shorting in the windings. You'll have to replace whichever part burned the windings and find out what caused the problem or you'll burn the new part the same way the original burned.
Mar 01, 2013 | Drills
I have a craftsman LT 1000 lawn mower that runs the battery down while it sits and it will not charge the battery while mowing even though the guage says that it is charging.
Something within the machine is discharging the battary, it does not sound like the engine is not charging, there is a tool called a negative shunt, it connects to the negative pole on the battary and enables you to connect a multi meter, this will tell you if there is a charge going out of the battary when the machine is switched off, you can then disconnect components to see which one is causeing the problem, a good mower shop should have such a tool .
Mar 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dewalt 18v XRP Hammer drill cause battery to burn, I'm talking flames and smoke. Motor run in both direction.
I hope this drill is still under warranty as the battery is in serious trouble. As long as the motor is turning, it should not be causing the battery to do this. Hope this helps!
Sep 23, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
New battery looses power after sitting a couple of days had alt check out it ok also checked if anything was drawing power when not running everything seems mormal
disconnect battary and see what happens ,if battary holds charge put an ammeter on the earth side of the battary to see if there is any current draw if there is a draw remove each fuse individually to see which circuit it is
Feb 23, 2010 | 2004 Jeep Grand Cherokee
Loud Electric Screwdriver Sound coming from the Engine
it sounds like it was just the electric fan turning on, they can and will turn on even if car is turned off.
Oct 26, 2008 | 2004 Dodge Neon
Drills Logo
98 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
