Question about Fujitsu LifeBook N3010 Notebook
Remove hard drive fujitsu n 3010
Diagram if possible
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
Diagram st380817as
If you mean a pin for the IDE connection you should be able to solder one back into the same place, you shouldn't need a diagram, also circuit diagrams would be very hard to come by.
Dec 25, 2013 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
Fujitsu LifeBook S710 hard drive cable
Has the Laptop been opened before? Usually a Laptop HDD just plugs into the connection, there are no cable connection connected directly to the HDD? The HDD may be Bad/Failed , remove and test.
Mar 01, 2013 | Fujitsu LifeBook S710 Core i5520M...
Mba3073np jumper setting
http://www.fujitsu.com/downloads/COMP/fcpa/hdd/MBA3xxxNx_Jumpers.pdf
Diagram and user-selectable options (on NP models only)
Below is a diagram of the main board of SCSI HDD and also a summary of the user-selectable options including guidelines for installation
of the HDD.
hope this helps
Oct 04, 2012 | Fujitsu (MBA3073NP) 73.5 GB SCSI Ultra320...
I have a fujitsu mhu2100at, ca06499-b11000c1. my hp laptop quit working and gave this error : PXE-E61: media test failure PXE-M0F: exiting PXE ROM. i removed the hard drive and tried hooking it up to...
The PXE error is not from your harddrive. the computer has failed to reccognise the HDD and so moved to the next bootable option being network, the PXE error is telling you that it cannot boot from network
I would only replace the board on the hard disk with another (same model) if you realy need the data on there. it is possible that the drive is failing because the heads have locked and so replacing the board will not fix, but if you have access to an identical drive its worth a try.
if you dont realy need the data, replace with another compatible drive and reinstall.
Mar 28, 2011 | Fujitsu Computers & Internet
Problem with Fujitsu MHT2080AH hard disk drive
Nothing can be done that is as cost effective as buying a new drive. Use the drive as little as possible, back up your data before it dies completely.
A professional could rebuild it for a few hundred dollars if you have a particular attachment to this exact model. But I can't think of any reason one might choose this route rather than simply buying another drive.
Feb 22, 2009 | Fujitsu MHT2080AH 80 GB Hard Drive
How do I remove a hard drive from a fujitsu lifebook T 4020 ?
underneath the laptop will be access panels, unscrew them and remove, the hard drive looks similar to this 95631bb.jpg
Nov 24, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Nov 03, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Fujitsu Siemens AMILO D-7830
HI! Yes you can upgrade your Hard drive from a 30GB (std size) to as much as 120GB. The only thing yu need to be sure of is that you need to buy a IDE 2.5" HDD which is a little bit hard to find but is still available. Try to google some suppliers online.
Hope this Helps.
May 20, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens Amilo d7830 hard drive
Yes, you can up to 120 GB IDE 2.5" HDD. You can buy it from any PC store near you ar order online.
Hope this Helps.
May 08, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu LifeBook N3010 Notebook Logo
229 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
