Question about Sanyo Cameras
Digital camera e870 not working error lens 21
  • 4,472 Answers
These are the steps to take when you have a lens problem.
If your camera is still under warranty, the best thing you can do is to take it to the nearest official repair shop and they should fix it for free.
If your camera is out of warranty, or if the manufacturer refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try the following methods to repair it yourself.
First, make sure your camera has fresh batteries and it is in recording mode.
Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
If none of that works I can assist you in having it professionally serviced though depending on the age of the camera sometimes replacement is the better option. Please take a moment to accept and rate my solution accordingly.
Thank you,
lee
Posted on Dec 25, 2008
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: sanyo vpc-E870
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 25, 2009
  • 102366 Answers
SOURCE: lens error:21/16 on my sanyo vpc-e870
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Lens 21 error vpc-e760
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Sanyo VPC-E760 Digital Camera
Lens error 21
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 15, 2009 | Sanyo DSC-MZ3 / VPC-MZ3 Digital Camera
Lens errors 21 and 16 when turning camera on
Jul 10, 2009 | Sanyo Vpc-s1070w Digital Camera
Lens error:21/16 on my sanyo vpc-e870
Apr 11, 2009 | Sanyo VPC-E760 Digital Camera
Sanyo vpc-E870
Jan 24, 2009 | Cameras
Lens error
Oct 12, 2008 | Sanyo VPC-S7 Digital Camera
Lens error: 16 HELP!!!!
go to the jugglezone.com there is a whole host of solutions for that problem.
also try putting your error message and camera brand on google and see what sites it gives you to check.
I was surfing yesterday and I know I found lots of help sites.
Aug 02, 2008 | Casio Exilim EXZ75 Digital Camera
My sanyo camera is not working
Well maybe I can solve this..... My lens would not retract and showed two error messages. Tried a number of tricks that have been recommended on this site to no avail. Ultimately what worked for me was pushing quite hard on the barrel of the lens trying to force it back in ( yeah i know, sounds extreme but did'n't think it could make the situation any worse ). The lens remained in the locked out position not moving in spite of the fact that I pushed it fairly hard. When I turned it on the lens retracted and it appears to be fully recovered from whatever was ailing it. Hope this works for you.
Jun 09, 2008 | Sanyo VPC-E760 Digital Camera
Sanyo vpc-E870
I have the same problem, my c amera is shut down when I want take pictures, show error 20
who can help me?
Apr 30, 2008 | Sanyo VPC-S7 Digital Camera
Sanyo vpc-e760 digital camera
i have the same problem ..
it was error 16 AND 21 .
im not entirely sure about the error 27 or any other
numbers ;
but i do know for a fact its because there
is something like dirt ; hairspray ; make up etc.
in the lens .
idk how to take the camera apart ..
but your best luck is to kind of jar your camera with your
palm or a book or something .
mine fell on the floor at first and was fixed ,
but today i dropped it in a little bit of sand and hasnt gone
back down yet .
im hoping i can fix it :/
let me know if any of you have any luck .
Mar 02, 2008 | Cameras
Cameras Logo
13 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
