Question about ASUS P5LD2 Motherboard
Boot problems I just upgraded my computer, everything is new except the hard drives. I performed a fresh install of Windows XP Home SP2 and it booted into Windows fine several times as I was installing various software. I was in the middle of the Nortons 360 install and Live Update wasn't happening. THe Internet connection was working. So I restart, get one beep and the regular start up happens, and then it went to a screen that was new that has a AMI American Megatrend logo over the top of the ASUS logo. At this point it freezes. I can go get into the BIOS (ver 1702) and it shows the hard drives and DVD-RW drive. No matter what I set as the boot drive, it never gets there. As soon as I exit the BIOS, it restarts and goes to the screen that it freezes on. It does not get to the DVD-RW drive, or get the hard drives to spin up at this point. Thoughts?
  • Daniel Van Amerongen Apr 17, 2007
    I reset the CMOS and and it booted just fine. Thanks for the help
  • Anonymous Mar 30, 2014
    No matter what OS I install Windows XP, Win7, or LINUX, as soon as I try to do ANY operation, install of software, or go online, it locks up totally freezes.
  • 944 Answers
CMOS reset definitely worth a try - works on most ASUS boards - i have the p5ld2 myself - havent tried on it but have cured similar problems with p4 series boards. once you have jumped the clr CMOS pins, you also have to take the cmos battery out for at least a few minutes for the clr to work properly. replace the battery if you can - these are cheap enough and there is no guarantee that a new machine to you has a new cmos battery. Hope this helps some, i'd like very much to hear the results in case it happens on my machine (touch wood) :)
Posted on Apr 14, 2007
    Brigadier General:
  • 6,966 Answers
Hi, since everything is new, you can probably ask your source to replace the motherboard since it looks like a bios/mb problem. If for some reason, you can not, them maybe you would want to try and update the bios. Their latest bios version is 1804 (for Asus P5LD2) and may be downloaded from http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5LD2. This is only if you are comfortable flashing since it involves some risk. Further, you have to follow carefully the flashing instructions. Bios are very specific to model and version of the mb. Hope this works out for you and please let me know how things turn up. Regards.
  • Louie  Role
    Louie Role Apr 14, 2007
    but then again, it might also be memory or video card problem.
    Other thing you can try is reset the the cmos.
    Cheers.
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
Copy WIndows XP from one hard drive to another
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
Jul 20, 2010 | Microsoft Windows XP Professional for PC
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Windows XP SP2 will not boot after installing new SATA hard drive
Your system thinks the "second" drive has precedence over the first ( your boot drive ) try switching the SATA cables between the two drives. There also might be a BIOS setting under Boot Order, sometimes you have to drill down to get to it for a particular drive.
Dec 25, 2008 | Microsoft Windows XP Professional for PC
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
How to install Windows XP Professional SP2
Check this Sol'n..
1. Boot(start) ur computer.
2. Press F2 to open up your BIOS Setup
3. Go to boot menu and set the 1st boot order to CD drive using function key. ex. F5
4. Change the SATA settings to IDE. Not
5. Save the new settings using function key before exiting. Ex. F10
It will restart and surely boot on your XP cd (if inserted)..
The rest are typical OS procedure.
From
#14DeeP
CCC-OTC Computer Operator
Mar 09, 2008 | Computers & Internet
Compaq 4400us windows install fails on errors
Microsoft Windows XP help Windows XP is available in the below versions:. Home Edition - Full / Upgrade ... Computer
Additional information and help with the boot.ini. If multiple operating systems are setup in the boot.ini, as the computer is booting you will ... Microsoft Windows XP Home Edition Microsoft Windows 2000 .
Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Compaq (388746-001)...
ASUS P5LD2 Motherboard Logo
337 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
