Question about Olympus FE-130 Digital Camera
Olympus FE-130 will NOT focus
Hi, my FE-130 won't focus; even on the sight screen. When viewing a subject on the screen it's only slightly blurry, but when I half push down the "shoot" button, the whole image on the sight screen becomes a blurr of colours with no distinguishable subject. The photo is the same. I've tried rre-setting, I've tried going to a different image mode (ie landscape as opposed to auto), all with the same result. The camera will NOT focus. Any ideas or help?
  • suerenea May 25, 2008
    My fe-130 will not focus either! view is blurry and clicks when it tries to focus. I have tried all settings with the same result.
  • 75 Answers
It sounds like the focus motor in the lens is jammed. This could be caused by a knock or possibly sand. You could try tapping the camera (not too hard...). This might free up the motor the only other solution is to take it to a shop.
Posted on Apr 17, 2007
My Olympus Fe-46 digital camera taking blurry pictures and buzzing when I turn it off?
this is a common problem with htc m7 & m8 they use a focus motor and get damage from motorcycle vibration or high shocks. i had the same problem on my m7 and m8, i took the phone to the supplier and i got new one instead.
now am using different phone when riding
Oct 27, 2017 | Olympus FE-46 Digital Camera
My Olympus e 510 is one year old. worked fine, but now is taking blurry pics. I tried all focus setting, including manual setting, auto-focus and even tried a different lens, still takes blurry pics. It...
I have the same problem and I strong suspect the circuit board is going bad. No matter what lens I use, distance from subject, etc. makes any difference. Unfortunately, the fix is about $200.00 - and having to invest $200.00 per year to keep it going is not a viable option for anyone.
Jan 23, 2011 | Olympus EVOLT E-510 Body Only Digital...
Olympys fe-270 takes blurry pictures
Try this. Aim the camera at the person/object you want to take a picture of. Press the shutter button "HALF WAY DOWN" wait 2 seconds then complete by pressing all the way down to take the picture. The auto focus works on the "half way down" stroke. Some cameras have a light that goes from red to green to let you know the focus was completed. Or, just wait the 2 or so seconds.
Dec 22, 2009 | Olympus FE-270 Digital Camera
My camera is acting up
check the lens the lens might be closed if are open and hold for 5 seconds if it doesnt work take it to a specialist
Aug 07, 2009 | Olympus FE-170 Digital Camera
Blurry images on camera
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
Picture is red and blurry
try to reset the camera through the menu or else it is in need of repair
Oct 16, 2008 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Blurry pictures
Try differential focus That is point to something near the distance you want- half depress the button -turn to subject complete the press down Bear in mind that if the subject is really close to the view finder is not looking where the focus window is-Parallax- learn to shift you frame slightly to allow for this.
May 13, 2007 | Canon PowerShot S2 IS Digital Camera
Olympus FE-130 Digital Camera Logo
206 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
