Question about Gateway (5500652) (  5500652) DVD Drive
Gateway laptop dvd drive does not start
"optiarc dvd rw ad-7563a ata device"
the device manager is saying the device cannot start (error 10)
  • 7 more comments
  • Anonymous Feb 21, 2009
    the drive is not being detected
  • mmitchell516 Feb 25, 2009
    The same problem and Gateway did not post a driver for the DVD RW Rom. I have searched and searched for the driver, Sony acts like it never heard of the deivce. I physically removed the drive from the laptop and reinstalled it, the bios saw it, Windows saw it also, but just did not install it correctly. Help would like to keep it in my laptop, but is currently going through the drives at work to see if any are compatible with my laptop that I can put my cover on it.
  • orveeyem Feb 25, 2009
    MY LAPTOP ALSO HAVING THE SAME PROBLEM OF DVD DRIVER PROBLEM. MAKE: GATEWAY .
    CD DRIVE MAKE: OPTIARC MODEL: DVD RW AD-7563A ATA.
    HO W TO SOLVE THE PROBLEM? NO ANSWER FROM GATEWAY.
  • Anonymous Mar 03, 2009
    My computer freezes up when a DVD is inserted
  • dvoorheis Mar 12, 2009
    The same Optiarc drive in a Gateway laptop.  Driver cannot be started.  I have seen several questions, but no answers.
    Uninstalling the device and rebooting did not work.
  • Anonymous Apr 03, 2009
    i cant belive that we all have the same problem but no solution mine only reads dvd's but no Cd's at all ive tryed reinstalling it over and over and nothing has changed
  • j_w_broerse Apr 09, 2009
    I have exactly the same problem. DVD/cd drive doesn't work at all. after uninstall and reboot the problem isn't solved.
  • Anonymous Apr 19, 2009
    same problem
  • garywwells May 08, 2009
    Optiarc DVD RW AD-7563A ATA Device in my Gateway computer will play DVD's but won't recognize a commerical audio CD nor a blank CD-R to record on. So far, Gateway Technical support has only provided "worthless" suggestions.
Http://support.microsoft.com/kb/314060/EN-US/
Posted on Mar 03, 2009
I just had the same problem (Windows XP)... here's what I did to fix it:
- Open Device Manager, IDE ATA/ATAPI controllers
- Delete "Secondary IDE Channel"
- Reboot
- After reboot, I got a the new hardware found dialog for the Opticarc. Just ignore it (hit cancel)
- The next New Hardware Found dialog box was for the Secondary IDE Channel. Just use the existing driver.
- Let it finish, then reboot.
The really weird thing is that I used Acronis to image the drive and restored the image onto another (exactly identical) laptop using Universal Restore and _still_ had this issue. Odd. But at least it's fixed now.
Posted on Jun 01, 2009
I was having this same problem. Mine now works! Go to gateway support, register your computer if you have not done so already--you will need your date of purchase, place of purchase, and serial #.
use online chat. allow them to share control of mouse--they were able to resolve the problem in about 3 minutes!
Posted on Apr 19, 2009
    President:
  • 1,179 Answers
Try uninstalling the drive and reboot. Usually Windows will reinstall the drive which fixes the propblem. If you are still getting error 10 after you reinstall then it is either a problem with the drive cable or drive itself. Hope this helps.
Posted on Dec 25, 2008
3 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: optiarc dvd rw ad-7563a ata device not reading discs?
Try this site....
http://support.microsoft.com/kb/314060
Posted on Oct 11, 2009
SAM1708
  • 68 Answers
SOURCE: My dvd does not play
Is this an internal or external drive? if it is an internal one then on the device manager screen where it is hows the yellow sign on signoptiarc dvd rw ad 7563a ata device, right click on that an click on uninstall.....And if any pop up comes up click on ok and restart the pc after that. Wait for the pc to reinstall the driver for the dvd drive. And then check the status of the dvd drive on device manager. If it does not have any yellow sigh then try again.
Posted on Feb 17, 2011
My dvd does not play error 10 device manager and yellow sign optiarc dvd rw ad 7563a ata device
Feb 17, 2011 | Gateway (5500652) (  5500652)...
My optiarc dvd rw ad-7563a ata device cant read dvd disk but it can play cd's ony
try re-installing deice driver....if do not work...replace the drive.
Sep 13, 2010 | Gateway (5500652) (  5500652)...
Optiarc DVD RW AD-5170a ata device. Cannot start code 10 error? any ideas why.
Possible cause of the problem:
1. Error 10 means that the drive driver is not properly or not installed in your computer.
2. You drive is broken.
Solutions:
1. Replug your drive wiring's inside the computer casing.
2. Check in the Device Manager in your computer if there is conflict in your drive. Go to Control Panel/System/Hardware/Device Manager to do this.
Nov 28, 2009 | Gateway (5500652) (  5500652)...
Gateway M-6848 arrived with vista home. used
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 14, 2009 | Philips (JR4DVDRWK/00) DVD+RW Burner
Optiarc DVD RW AD-7563A ATA Device will not play cd's/dvd's My device used to work good, but suddenly it stops working. It doesn't do nothing at all, doesn't burn a cd or dvd, but either read it. And in...
If the drivers have been updated recently, go to the properties page for the device and click on the Rollback drivers button. Reboot the machine and try using the drive again. If that does not work, you can go into Device Manager, right-click on the drive and select uninstall. Reboot the machine and it should re-detect the drive and reinstall the proper drivers.
Jun 01, 2009 | Gateway (5500652) (  5500652)...
It seems to be a common problem on the gateway systems. To correct this you need to go into your Registry Editor. Go to HKEY_LOCAL_MACHINE/HKLM\System\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} When you click on {4D36E965-E325-11CE-BFC1-08002BE10318} look in the right side box. You should see an entry labeled UpperFilter delete this entry. You may also have a LowerFilter if so delete this as well. Exit Regedit and reboot. This solved the problem for me.
Apr 25, 2009 | Gateway (5500652) (  5500652)...
Optiarc dvd rw ad-7563a ata device - code 10
Download the "cdgone" patch from the llink below and run it. This will solve your problem
Mar 05, 2009 | Computers & Internet
Open Questions:
iTunes can no longer find my CD burner. Using a gatewayM-1631U laptop, with windows 7 x 64 home premium edition. (See additional details below). I use iTunes regularly, and as recently as Xmas 2009 was burning music CDs frequently on my laptop. Yesterday I attempted to burn a CD, and iTunes no longer recognizes the installed CD burner. I have not installed any programs to my computer recently, or made any other changes. Today I began investigating the issue. I have tried (not in order) the following - and have not solved the issue: 1. Going to the registry editor and deleting the lower and upper filters associated with the H_KEY_LOCAL MACHINE/SYSTEM/CURRENT CONTROL SET/CONTROL/CLASS 4DE3695 .... 2. Uninstall and reinstall iTunes (9.0.2.25) 3. Repair iTunes 9.0.2.25 4. Looked for updates for the drivers (can't find any) 5. Downloading Gearsoft products I admit that I have not tried Windows Media Player (because I'm committed to my iTunes - I sync with my ipod all the time and listen to it alot). I also realize I may have made the problem worse by some of my attempted fixes. Here is the information gathered through itunes diagnostics: Microsoft Windows 7 x64 Home Premium Edition (Build 7600) Gateway M-1631U iTunes 9.0.2.25 QuickTime 7.6.5 FairPlay 1.5.23 Apple Application Support 1.1.0 iPod Updater Library 9.0d11 CD Driver 2.2.0.1 CD Driver DLL 2.1.1.1 Apple Mobile Device 2.6.0.32 Apple Mobile Device Driver not found. Bonjour 1.0.6.2 (118.5) iTunes Serial Number 2987488CE609EDAB Current user is not an administrator. The current local date and time is 2010-02-05 07:50:22. iTunes is not running in safe mode. Video Display Information ATI Technologies Inc., ATI Radeon X1200 Series **** External Plug-ins Information **** No external plug-ins installed. iPodService 9.0.2.25 is currently running. iTunesHelper 9.0.2.25 is currently running. Apple Mobile Device service 2.50.39.0 is currently running. **** CD/DVD Drive Tests **** No drivers in LowerFilters. UpperFilters: GEARAspiWDM (2.2.0.1), Failed while scanning for CD / DVD drives, error 2380. Error while opening iTunes CD driver. This could be caused by a corrupted iTunes file or a conflict with other older CD burning applications, either currently installed or previously installed and uninstalled incorrectly. Additionally, the device driver says my DVD/CD unit is: Optiarc DVD RW AD-7563A ATA Device Anything else you need to help me figure this out? Could really use help and advice. Thanks in advance.
Feb 05, 2010 | Gateway (5500652) (  5500652)...
See all Gateway (5500652) (  5500652) DVD Drive Questions
Gateway (5500652) (  5500652) DVD Drive Logo
4,160 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
