Question about Haier XQJ50-31 Top Load Washer
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
Hi, i load my clothes evenly into the washing machine and everything is fine until it gets to the rinse/spin cycle. The machine won't spin because through the cycle it has piled the clothes up to one side. I have to manually reload the clothes around the machine in small loads and then it spins. Why does it push the clothes all to one side when I have loaded them all evenly around the machine? Seems strange to me.
  • 2 more comments
  • Faylene Ferris Apr 14, 2007
    Hi thanks for your comment but I didn't overload the machine. The load that I put in was less than the maximum load capacity.
  • dano505 Apr 23, 2008
    My washer will not spin at all,even if the machine is empty of clothing.
    Dano505
  • Anonymous Mar 23, 2014
    even when you balance load spin cycle not able to continue too much out of balance on spin cycle
  • Anonymous Mar 26, 2014
    wont spin with clothes loaded
    President:
  • 1,294 Answers
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Posted on Apr 14, 2007
  • prem mathew Apr 14, 2007
    1) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
    2) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson.
    3) Call an appliance repairperson; there may be a problem with the controls.
My AEG washing machine W1037 washes perfect but do not spin the cloths comes out wet
Possible imbalance:
  • When the washing machine will not spin, this may not be due to a fault on the machine. It may be due to the electronic balance check.
  • The electronic balance check ensures that the clothing is balanced inside the washing machine before the appliance starts to spin. This prevents your washing machine from being subjected to uneven loads, which can damage the machine.
  • The electronic balance check also means that your washing machine will not be able to spin a single garment or a few garments because it is unable to balance the machine. If the imbalance exceeds 0.5 kg, the spin function will not operate.
  • In the case of a single garment or a few garments, there will be nothing wrong with the washing machine. You can work around the problem by placing a few towels in the washing machine. Towels help the washing machine to balance the load and spin.
  • You can test your machine by spinning with an empty drum (without any garments). If this works, the machine is working properly.
  • Overloading the machine can also cause the machine not to spin.
If none of the above suggestions resolve the problem, we recommend contacting an Authorized Service Center.
Rinse hold selected:
  • If rinse hold is selected, the washing machine does not spin at the end of the cycle. If there is water in the machine after washing, select and start a pumping cycle.
Level:
  • If the appliance has not been installed so that it is level, it may cause the machine not to spin. To level the appliance, adjust the appliance's feet and check it with a spirit level.
Unstable base:
  • If the base on which the machine is placed is unstable, e.g. a wooden floor (not a solid level base), it may cause the machine not to spin. If the base is not level or firm, movements may occur in the machine which prevent it from balancing itself.
Dirty filter:
  • If the drainage does not function properly, it may cause the machine not to spin. Clean the drain filter and the pump blade (if the pump blade is visible, turn it using a pencil and remove any fluff or foreign objects). Then refit the filter and start a hot wash without any soap to clean the machine. Check if the drain hose is set at the proper height (min. 60 cm - max. 90 cm) and if it is not put too far down into the drain (max. 10 cm).
Jun 02, 2018 | AEG Washing Machines
Washing machine tub is banging into the side of the walls..what's the problem here
There are two possible causes for when a washing machine jumps and bangs on spin. Either the load is a bad one and unable to be balanced, or a fault is preventing the machine from balancing the load (or causing the motor to surge into spin when it shouldn't). This causes the laundry to be flung around inside. The occasional jumping around may not be anything to worry about, but regular or severe occurrences should be a cause for concern and can cause expensive damage to your washing machine if ignored.
Both these faults are less common these days because manufacturers have built in certain protections, but it's still something that can happen. To differentiate between the two, observe when the problem occurs, if it's during a wash cycle, maybe at random parts of the programme, it may have a fault which really needs an engineer to diagnose as these faults can be intermittent and tricky to diagnose. If it happens when it kicks into the fast spin the chances are it's related to the load inside.
Am I overloading my washing machine?
By out of balance I mean when the washer jumps or bangs quite violently. If the washer is just rocking about on most spins make sure it's on a level floor and that it is properly level.
If a load is out of balance you can often observe the inner drum swaying about or even thumping the sides of the casing a few times whilst it's trying to distribute the load prior to fast spin. Before a proper spin the drum should revolve slowly for a couple of minutes. This is called "distribute" and at this stage you may see large flashes of metal drum on each revolution where all the laundry has settled around the drum but there wasn't enough to cover all of it. If this happens the drum will be out of balance and either refuse to spin, or if allowed to spin may cause the drum to thump around and hit the sides of the casing.
The best way to avoid unbalanced loads in a washing machine
If you try to wash a bulky, heavy and absorbent item, the washing machine is unlikely to be able to get it to balance inside the drum. Or if you put just a few large towels or a heavy item in amongst some very light fabrics the heavy items could bunch to one side of the drum and the lighter ones won't be able to counter-balance their weight effectively. There should be enough items to fit all around the drum. If there's only enough to fill most of the drum, but a section is empty, then it can get out of balance on spin. If the items are all light, then this may not cause a problem. However, if some items are heavy, they may cause violent banging, or the washing machine out of balance detection may just refuse to allow a spin.
Make sure you fill the drum well. Counter to expectations, the worst violent spins are caused by under-loading - not overloading. Heavy bath mats are notoriously difficult to balance and should ideally be washed with other items or they may gather on one side of the drum. However, some people (understandably) don't want to mix the bath mats in with normal washing. If this is the case and you do get problems with the bath mats getting out of balance I suggest you use old towels or sheets to even the load up. With most modern machines though, a heavy bath mat is more likely to just not get spun rather than be allowed to spin out of control and wreck the machine.
Sometimes you can get an unbalanced load by sheer chance, with loads you have successfully washed many times before. The occasional bad load is inevitable but constant bad loads and violent banging on spin should be looked into. [ Related: loading the washing machine properly ].
Modern washers have built in out of balance protection
Most modern washing machines now electronically monitor the motor during the slow distribution section leading up to the spin. If the load is out of balance, the motor shouldn't be allowed to spin. Typically, a modern washing machine will attempt to balance the load a certain amount of times, or for a certain passage of time, but if it can't, it will either reach the end of the program without spinning, or it will abort spin and turn off. (both scenarios leaving the clothes wet through). Some washing machines may allow a slow spin if the clothes are reasonably balanced, but then unless they settle down, it will not allow a higher spin thus leaving the clothes spun, but much wetter than normal.
Some will indicate a failed spin due to being unable to balance the wash load so check your instruction book to see if your washing machine has this function and what happens if a spin is aborted. Unfortunately some washing machines do not adequately inform the user that it failed to balance the wash load and aborted spin. As an engineer, I have been called out many times because a load was washed but not spun, but there was no fault on the washing machine, just an aborted unbalanced load.
Extra large drums make balancing loads harder
These days you can buy washing machines with much bigger drums. The average drum size was at one time a mere 4.5Kg but is now 6Kg. You can buy washing machines with 7Kg, 8Kg and even 10Kg drums.
These washing machines can be more prone to refusing to spin some small loads because they need even more items to fill the drum. For example, my 7Kg washing machine will not spin 3 large towels. Last week my wife was extremely frustrated with our 7Kg drum washing machine as she had just washed our son's hoody-top and wanted to spin it in the washer. It simply would not spin, so I advised her that it needed something to balance it out. She put in a couple of towels but still no spin. Eventually 5 towels were needed to balance out the absorbent top and allow a spin. This is a minor inconvenience compared to the benefit of being able to fit more washing in (even our king sized quilt) but it highlights how if you have a very large drum it could be more prone to not spinning small loads [ Washing machine won't spin just one item or very small loads ].
I'm loading the washing machine correctly but it still bangs and jumps on spin
This is unfortunately a difficult fault to diagnose. It could be various things including a faulty connection somewhere on the motor or pcb, especially if intermittent. It can be caused by a part overheating, cutting out and then cutting back in causing loss of control. If this fault isn't caused by the loading you really need to get an experienced engineer to look at it. Find a washing machine repairer on Washerhelp
If a brand new washing machine is jumping around on spin
Make sure you have removed all of the transit packaging before using a new washing machine. The transit packaging stops the suspension from working so without the tub being able to bounce up and down on the suspension all the movement created on spin will be translated to side to side movement and the washer will move about and shake.
Loading washing machine White Goods Help washing machine jumps and bangs on spin Washing machine won spin just one item Book washing machine repair
Aug 02, 2015 | Washing Machines
It doesn't self balance and spin out all the water from clothes. the clothes are very wet, especially jeans. And the washer rocks bad during the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | GE WSXH208A Front Load Washer
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 05, 2010 | Frigidaire Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Haier XQJ50-31 Top Load Washer Logo
516 people viewed this question
Top Haier Washing Machines Experts
shaun taylor
jimorris77
Jim Goldsmith
Jim Goldsmith
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
