Question about Kenwood KAC-9102D Car Audio Amplifier
When I ignite my stereo system the indicator of ignition of my KAC-9102D is blinking
I' don't know what's going on with my amp because it's been working well for 2 years and two days ago i started to see that something was happening, when i used to turn the volume up the subs didn't responde and right now the amp it's not working also the power indicator on the amplifier it's blinking. Please if someone had this problem before just let me know what to do
  • Juan Lora Apr 16, 2007
    Thanks man, i already went to repair it. It was something on the amp not on the power supply. Hopefully the guy told me it's not a major problem and it will be done on thursday. Your answer was good it was like you said something that needs to be replace.
    Thanks
So what was the problem because mine is doing it now and i just kind of want to know so i can go have the guy fix it thanks
Posted on May 24, 2007
  • 944 Answers
Here is the link for the user manual for your amp if you need it; http://akamaipix.crutchfield.com/Manuals/113/113KAC9102.PDF There appears to be no designed error code indicated by a flashing power light. the light is either on or off.(page 2) I think therefore that your amp has a major problem in the control part of the circuitry, almost certainly something that needs replacing rather than being repairable. if you wish to try yourself then if you can open the amp up, and post us some clear close up photos then we may be able to help. If you wish to find the nearest Kenwood dealer then; http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=38 Hope this helps - sorry if it is bad news :)
Posted on Apr 14, 2007
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
1 amp cuts off
i had this same prob. & i run 2 amps as well, cameto find out i had a neg. & positive touching , so check all ur wiring for tht amp..
Apr 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
No out put
Hi - You can download the manual by clicking the link underlined in blue below:
KAC-9102D
Check the installation is correct!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 08, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Aug 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Car audio
Make sure that you are running the engine every time that the stereo is playing or you'll deplete your battery's voltage. Also, make sure your alternator can supply the amount of current necessary to produce that kind of power. Amps X Volts = Watts is the formula you use to calculate this demand.
Jul 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Doesn't turn on
You need to confirm that the B+ voltage isn't dropping at the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
May 21, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Problems with my Subs amp
Here is the link for the user manual for your amp if you need it; http://akamaipix.crutchfield.com/Manuals/113/113KAC9102.PDF There appears to be no designed error code indicated by a flashing power light. the light is either on or off, and if the protection is on then the light is off.(page 2) I think therefore that your amp has a major problem in the control part of the circuitry, almost certainly something that needs replacing rather than being repairable. if you wish to try yourself then if you can open the amp up, and post us some clear close up photos then we may be able to help. If you wish to find the nearest Kenwood dealer then; http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=38 Hope this helps - sorry if it is bad news :)
Apr 13, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Will it work together
put a the amp the max charge permitted, and y you have a preamp you can makeit work.
Feb 10, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
88 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
