Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE4 latch will not unlock, unable to close door
Came home to an open door and the machine still on. the latch is locked and unable to lock the door
  • 179 Answers
Is there water in the machine if so you need to clean your pump there is a safety feature on the washer that does not allow the door to open if there is water in the machine if you open the pump be sure to have plenty of towels around
Posted on Dec 26, 2008
Kenmore Elite front load washer 4110 door latch with safety lock is in lock position with door opened. How do I unlock
Solenoid prob stuck unplug machine and the plug it back in and see if it stays unlocked
Mar 01, 2015 | Kenmore Washing Machines
Kenmore elite washer he4 door striking mechanism
if the machine has stoped and unlocked you should be able to pull straight out
May 03, 2014 | Kenmore Elite HE4 Electric Dryer
2005 chevy trailblazer ext back hatch lock is engaged and will not open leaving the door unable to close
Open the hatch and slip a screwdriver's shaft into the opening of the latch (simulating that the latch has engaged the metal bar on the floor of the SUV). Apply pressure in the latch via the shaft of the screwdriver. While pulling against the latch, operate the unlock button of the fob or unlock with the key (whichever your truck has). When it is unlocked the latch will allow the screwdriver to open the jaws of the latch and pull through them. The latch jaws should now be open and you should be able to close the hatch and have it latch and lock.
Mar 02, 2014 | 2004 Chevrolet TrailBlazer
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
My car door does not close,door lock is jamb
Check the latch assembly where the door closes. If the latch claw is closed it won't latch. Make sure the door is unlocked. Insert a screwdriver into the middle of the claw (circular opening where the striker latches). Open the door handle from inside or outside and pull sideways on the latch it should pop open. If it doesn't then the lock mechanism is in the lock position. Remove door panel follow lock rod to the latch and manually try to move the lever to the unlock position. If all fails you probably will need a new latch assembly.
Jan 30, 2011 | 2000 Ford Taurus
Kenmore Elite HE4 won't start
Top 10 front-load washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisy,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nesessary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Over-sudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 06, 2010 | Kenmore Elite HE4 Electric Dryer
I couldn't get the washer to start (HE 4T). It
DL stands for Door Lock failure, if your door isnt closing all the way, check to make sure your hinges are lining up and that one of the arms has not broken off on the door, there should be 2 arms going into the door lock. whats common on these is that the door latch has trouble unlocking so it is forced open and now the door latch mechinism is stuck in the locked position and cant re-open. problems with this lock opening and closing- 9 times out of ten, come from a main computer failure to send power to the door lock. this can be temporairily fixed by re-seating the door latch wire harness in the main computer, but its usually recommended to buy a new computer since this problem has been address on the new series of computer. there is no recall on this board at the moment. estimated cost $250-$400
Nov 24, 2009 | Kenmore Elite 45986 Front Load Washer
Door locks won't let you shut the doors
Any possibilities of coats, clothing brushing against dooor and INADVERTANTLY latching them closed ? OK heres how to open the latch. Make sure door lock is in the UNLOCK position. With one hand , lift and HOLD up, OUTSIDE door handle, while taking your pointer finger and flipping open the latch on the side of the door. VOILA Hope this helps
Apr 12, 2009 | 2000 GMC Safari
HE3 lock
Have you tried pushing the door lock/unlock button? I think it may be called the "rinse & spin", and under that it says door lock/unlock.
Sep 20, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
83 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
