Question about Hitachi 46BX01B 46" Rear Projection Television
Heard a POP then no picture!
Hithachi 50 in model 50sbx78b rear projection.
How do i fix this problem? is it easy to relace a lamp? how many? how expensive?
is this the obvious problem? lamp has not been changed in 10 yrs
tv has had minimal usage.
Help!
Thanks!
You need a new bulb, my tv did the same thing.
Posted on Dec 25, 2008
Tv wont turn on. flashes yellow twice over and over again
needs a new lamp.easy to relace youself.get the model number.go to ebay look up model number and lamp.get it with housing.cost about 50 dollors.thanks
Nov 20, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
I heard a "pop".
HD50LPW62 is Not projection,Projection TVs have 3 Tubes R/G/B.
Your TV is DLP which has Lamp and Color wheel, Ballast board, Lamp Fan.
You need to Check the Lamp,You will need to remove the back in order to see the Lamp.
Lamps are easy to replace.
Mats Electronics has Lamps 1-800-628-1118
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Have jvc model HD56G886. heard a pop..picture went off...blue light over on/off switch blinks quikly. Lamp go bad?
lamp is burned out, reorder one online and install-cheap and easy, the lamp will come with instuctions
Jan 15, 2010 | JVC HD-56G886 56" Rear Projection HDTV
Tv dead
hello. the loud pop you heard was .maybe a fuse.? u need to uplug .!!! the set !!!. and take off the back and see if fuse is bown.? ok let me know.!! ok
Jun 02, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tv will not power on
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
May 01, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Nothing on my TV
This set has CRT guns. 3 of them. No bulb.
Check and see on this site what others have suggested for your problem.
Without seeing it I'd say main AC fuse
Mar 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Lamp flickering
Well jumping has nothing to do with lamp so called bulb.
You have what I would call a cold solder joint.
You're going to have to open the set and tap gently to see were it is comming from. If you know anything about soldering they you will know it is not that easy.
Once you think you have found the place were it seam's to be the place were it make's it jump more often, start again to make shure that's the spot and not the hole area.
Then remove the board and resolder,
Good luck
What About Bob
Timmins, ontario
Home of Shania Twain.
Mar 15, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 46BX01B 46" Rear Projection Television Logo
107 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
