Question about Vtech V.Smile TV Learning System
V-smile will not load the game - what can be the problem? Thank you!
  • 8,596 Answers
Make sure the system is turned off before inserting the cartridge. Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Posted on Jan 04, 2009
Tip
THANK YOU, THANK YOU, A MILLION TIMES I THANK YOU!!! ALMOST GOING TO GO OUT AND...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Sep 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to clean games and games keep freezing on my son
You can use a pencil eraser to clean the contacts on the game cartridge
May 07, 2009 | Vtech V.Smile Smartridge: Dora's Fix-It...
Game will not start
Turn the cartridge the other way and try pushing it in with the game name facing towards you. This should work.
Dec 29, 2008 | Vtech V.Smile TV Learning System
My daughter v smile pocket does not work
Sounds like the contacts on the games need to be cleaned. On the game cartridge, push back the little cover and clean the gold colored contacts on both sides. I use a cotton ball or q-tip with alcohol on it. Let it dry before you put it back in the v.smile.
Dec 09, 2008 | Vtech V.Smile Pocket Pink Electronic...
V tech smile.
It sounds like you need a new cable that runs from the unit to the TV. Check the cable for cuts, etc.
My kids damaged mine closing the entertainment center door on it. I cut the wire, reconnected the wires all and taped it back up. Works fine now :D
Dec 05, 2008 | Vtech V.Smile TV Learning System
V tech v smile games
clean the metal with rubbing alcohol
Nov 22, 2008 | Vtech V.Smile Pocket
Any ideas on the v smile game???
yes this will be permanet damage .
Aug 11, 2008 | Vtech V.Smile Adapter
KB Gear Little Tikes 3D Cruiser Wheel
This web address is not a web site. It is a downloadable program. It will not appear, but should trigger your computer to "SAVE TO DISK" or "DOWNLOAD". Choose yes and save to disk. Then run a CD burning software such as Roxio and load the .ISO file. It will create a CD. THis CD you can then run and it will install the program to operate the 3D wheel.
Jul 22, 2008 | KB Gear Little Tikes 3D Cruiser (1727)...
V-smile crashed
Our daughter got one last christmas, after 6 months or so, it has stopped working. It was a present from grandama and I don't think it has a warranty, certainly no receipt can be found. It's very dissapointing and I have heard from other parents who bought this V-Smile that theirs just stopped working too for no reason. We thought it was the batteries, so kept buying more, then we got the adaptor, still won't work. Now and then it works, but not often.
Jun 11, 2008 | Vtech V.Smile Adapter
Vtech V.Smile TV Learning System Logo
194 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Keith Koene
donny ardalando
donny ardalando
Are you a Vtech Toy Expert? Answer questions, earn points and help others
