Question about ECHO, Inc. PB-251C Handheld Blower
Runs fine &then suddenly stops
My leaf blower runs fine for about 10 minutes and then just stops! (Little Wonder 9666E).
Then it wont start for a day or so, but then starts fine again, and then the same thing happens?
I think it has something to do with the tubes entering the fuel tank (fuel or breather).
Can you help me answer this.
Kind regards,Adam.
  • 23 Answers
IN the tank there is a intake tube on the bottem of that tube is a tiny filter. you can reach in and pull it out the tank enough to work on it.
It is clogged pull it off let it dry for a day and then blow it clean fron the gas line side OUT.
or echo sells tune up kits for 10 bucks at home depot. -Jeff Anchorage Small Engine.
Posted on Feb 04, 2009
What is the compression on a poulan leaf blower?
60 to 70 psi it will start fine. I fix Poulan blowers every day for a living
they are very easy to fix. A common problem is stuck piston ring.
Jul 10, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Can't get a brand new little wonder LB900 blower to start
Needs fuel,air and spark.
Inspect "sparkie".See if there is a spark(when grounded),during start.
If so,is the sparkie fouled with fuel or carbon?
Smell the gasoline.If it's bad,it won't run.
Possible carb problem.(Fuel delivery)
Heat the carb w/a hair dryer. That works wonders!
May 18, 2014 | Little Wonder Lb900-00-o1 9 Hp Honda...
My echo pb-201 hand held leaf blower starts and runs for about 2 minutes then begins to sputter and stop. Sometimes I can get it to work for about 4 minutes but then stops.
may be a clogged fuel filter or bad fuel lines check to see if they are real soft if so replace it they are fine the may need a carb kit
Jan 13, 2011 | Echo Garden
My blower only runs about 3/4 choke position. Behaves as if it is starved for fuel.
It may be, doesn't take much to clog the ports in those little carburators.
I'd empty the tank and make sure my tank of gas isn't contaminated.
I had to remove my carb, disassemble it and soak the body in fresh gasoline for 10 minutes then blow it out. Now it runs better then the day I bought it
Jan 06, 2011 | McCulloch 26cc Gas Blower Mcb3208
It only runs for about 5 minutes at a time.
The ignition module is going bad. Cost of replacing part is more costly than buying a new blower.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Mower wont keep running
recycler toro 6hp. 10 years old,little usage. Starts then stops, have to keep priming. Can anyone help?
Jun 14, 2009 | Toro Lawn Mower With Toro Power Tools
Electric snowthrower motor turns, blades don't
You will have to take the top cover off of the snowblower there should be a belt that runs the auger
Dec 09, 2008 | Garden
ECHO, Inc. PB-251C Handheld Blower Logo
879 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
