Question about Durabrand HT-3915 System
Please help me,
I need to know which plug in's the red, white, and yellow knobs go to on both my system and my tv?
Red&white plgs are audio connections and yellow is vedio plug
Posted on Jan 26, 2009
  • damu_shammy Jan 26, 2009
    this is correct
    Genius:
  • 1,066 Answers
Red is left channel audio, red is right channel audio and yellow is video.
Posted on Dec 24, 2008
Which do i plug red yellow and white into
If you are using the RGB (red, green, blue) and the the red, yellow, and white cables. Then the RGB cables are in place of the yellow, you should plug the cables into a Component input on the tv you are using. The red and white cables are the audio cables and should be plugged in but the yellow will not be used if you are using RGB.
If you have only the yellow, red, and white cables, just match them up with an input on the tv or any player that has the inputs.
If you need a new cable, Amazon sells one along with any local store such as Walmart or Best Buy. http://www.amazon.com/PlayStation-3-Component-AV-Cable/dp/B000MIXFWA
Does this help? If you have further questions, please let me know.
Benjamin
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
Only VCR2 sound working, no video
if you want you can bypass the video instead of plugging it on your system feed it directly to your tv., you only need the white and red cables for your audio to work, red for right channel and white for left channel the yellow one is for video, you can directly plug it on your tv
May 05, 2010 | RCA RT2250 System
How do i connect the playstation 3 to tv, it was connected to hd tv then we have tryed to connect to normal tv and nothing. please help
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
Jan 08, 2010 | Sony PlayStation 3 40GB System
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
V smile learning game
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
Also, you mentioned SCART. If your TV is in Europe, and the unit you have was designed for the US, the power supply isn't going to power the unit without an additional transformer. Also, the US models might have a native color system that is incompatible with PAL.
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Nov 23, 2008 | Vtech V.Smile TV Learning System
Something with the screen
-Tha Mp3 Doctor
Nov 21, 2008 | Vtech V.Smile TV Learning System
Set up
The red and white plugs are audio - they should go to one of the receiver's inputs.
The yellow plug is composite video - if your receiver has a yellow jack, plug it into the receiver (this will let you switch inputs from the receiver), if not, plug it into your TV.
Same goes for your tape deck, though it won't have a video output.
Apr 05, 2008 | JVC THD-50 System
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Durabrand HT-3915 System Logo
47 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
