Question about Refrigerators
Just moved into a house with a Danby "Millenium" wine cooler that fits under a counter. I plugged it in, turned the temperature control using a coin, nothing happens. No noise, no cooling, light doesn't even come on. Plugged into another outlet as well. Can't find a manual at the Danby site. Is there anything more to turning it on that just the temp control?
  • 700 Answers
You can try this link for a manual for your wine cooler manual
http://diplofix.com/forum/DANBY hope that they have what you are looking for and thanks for using FIxYa.
Posted on Dec 24, 2008
Danby wine cooler refrigerator temperature control won't work
Without more details on what you're observing, I can't say for sure what could be wrong. I can just tell you that I had problems with the temperature not controlling properly, and the set temperature seeming to vary on its own. It turned out that one of the 5-wire bundles that plugs into the back of the controller (PCB) was snugly pressed into the pins on the back of the circuit board, which was causing shorts in the control circuits. I inserted a piece of heavy cardboard in between them to ensure separation, and presto, my machine now works correctly again. So before buying parts, I would suggest you examine the control board and wiring for possible problems like this.
Sep 02, 2014 | Furniture
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
Temperature control non-functional
I found a repairman who knows how to replace failed thermostats using other than OEM equipment.
WSN
Jan 17, 2009 | Danby Silhouette DWC512BL Wine Cooler
Avanti Wine Refrigeraator
thanks for the question i think the problem is that its under the counter no air flow to cool the coils try it not under counter thanks the appliance doc
Sep 24, 2008 | Danby DWC283BLS Wine Cooler
How to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Jul 31, 2007 | Danby DWC513BLS Wine Cooler
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
