Question about Dell Dimension 3000 PC Desktop
Dell Dimension Computer will not turn on
The button to turn on was taking a few pushed to turn on. Once it started all was ok. It finally just stoped turning on. There is a yellow/orange light blinking on the buttin but nothing turns on. Once it turns on if I don't shut it off it is fine forever so I am thinking it might be the on/off button but not sure. Anyway, to hotwire these computers if the switch is not working?
  • trautman2 Jan 18, 2009
    my dell has just recently begun to not want to turn on. While attempting to turn it on, it has yellow blinking light on the power switch. How can I fix this? Do I have to take it in to a computer guy to fix? Are there instructions anywhere that I can download to fix this?
    President:
  • 1,179 Answers
The orange flashing light is an error code. You can call Dell support and they will tell you what the code means. Usually it is a graphics card, motherboard or RAM issue. Hope this helps.
Posted on Dec 24, 2008
  • 50 Answers
Hi try taking the front face panel off first and see what is obstructing the button and put the panel back on again.If you dont know what to look for behind the panel then its better to take it to a repair shop.
    Problem Solver:
Think you need to contact manufacturer
Posted on Sep 28, 2011
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
FIXYA The power supply output of my Dell Dimension 8200 desktop pc is delayed for minutes after i press the ON button in the tower front. The momentary button switch is OK. The delay is 15 minutes if
It's not about the switch, a problem may be caused by bad power management control driven by XP. Ask on DELL's forum about any patches about this. Finally, check-up your power management scheme.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Mar 06, 2014 | Dell Computers & Internet
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
The 3 and 4 are lit up on the front of my dell desktop. the computer turns on but wont start.Also once it is on it wont turn off by pushing the power button, I have to unplug it. please help
Open up your tower and take out the ram. Then put it back in and close the case. Make sure your power cord is disconnected when you do it. Then restart and see if it helps.
Mar 12, 2011 | Dell Dimension E520 PC Desktop
My Dell Dimension 9150 will not turn on
Use your CD to boot up the computer and recover your operating system
May 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell dimension 3000 desk top, does not turn on ?
It's one of two problems: bad power supply, or bad motherboard. If you are electro-mech inclined, remove the power supply. Take it to your local computer repair shop, and ask for one just like that one.
Reinstall, power up should (most of the time) fix this problem. If still no power, you need a new mb. Return to the shop, ask them to replace mb. This repair should be right around $250.0 - tops. Any more than that - replace computer.
Hope this helps. Either way, if you wouldn't mind taking the time to rate my response, it would be much appreciated!
Thanx and good luck.
gurutim
Mar 22, 2009 | Dell Dimension 3000® Pentium® 4...
Start up problems
Normally, when the Dimension L-series gives a Press DEL to continue, it is an indication that the Hard Drive (Where data is stored) is failing.
At the Dell Screen when the system is 1st turned on, press CNTL+ALT+D to run a quick diagnostic on the hard drive. If there is a failure, you will get a failure code (Code 3, Code 4 etc) if the drive passes, no failure was detected (Doesn't mean one doesn't exists though)
To run more diagnostics, you can boot to the Dell Dimension Resource CD if you have it and run Dell Diagnostics from the CD.
May 12, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 3000 PC Desktop Logo
560 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
