Question about Kenmore 64902 Electric Dryer
Kenmore Dryer Timer does not advance
I have a Kenmore Dryer that the timer will not advance. The dryer does everything just fine, except the timer will not run. I have replaced the timer, but the problem still persists. All voltages going to the timer motor are good and a resistance check of the timer motor reads about 16 ohms. Can anyone provide an assist?
  • 3 more comments
  • Jeff Rockwell
    Jeff Rockwell Jun 16, 2007
    Thanks for the assist, but I managed to figure this one out. The replacement timer I was shipped was the wrong part number. Once I received the CORRECT part, I managed to get everything running just fine.
  • assilem70 Nov 02, 2008
    My dryer timer wont advance, have replaced it 3 times and none of them have worked. I had them tested when I took them back and no response when put on the meter that tests if its good. The appliance company wont refund my money only get me another part. Is there any thing I can do I can't afford to go buy a new dryer it was 124.00 for the timer alone. It was hooked up exactly the way the diagram instructs but still no movement of the dial.
  • Anonymous Mar 16, 2014
    Replaced everything but the timer and motor
  • Anonymous Mar 19, 2014
    OTHER THAN THAT THE DRYER WORKS GREAT
  • Anonymous Mar 28, 2014
    will schematic help
Kenmore dryer timer won t stop turning
Posted on Jan 24, 2008
  • 87 Answers
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Posted on Jun 13, 2007
SOURCE:
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Electric Dryer Model 110.6972110 timer motor NG
hi,
maybe call a generic appiance store other than sears, try maytag store. the knob pulls staight off and the timer nut is below. then take off the back cover off the control panel, sometimes those screws are on the front corners, sometimes hidden. take a picture of the timer wiring and tape and label all the wires before you remove it. unplug it first!!
jm
Nov 29, 2009 | Kenmore 62602 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore drier model 110.96591440 will not cut off in either drying cycle
DO YOU MEAN IT WON'T SHUT OFF? DOES THE TIMER ADVANCE? IF IT STAYS IN THE SAME PLACE, AND YOU ARE ON AN "AUTO DRY" CYCLE, THE TIMER WON'T ADVANCE IF THERE IS A RESTRICTION IN THE EXHAUST.
DISCONNECT THE DRYER EXHAUST FROM THE BACK OF THE DRYER AND TRY ONE LOAD OF LAUNDRY. IF IT WORKS O.K., THERE IS A PROBLEM WITH YOUR DRYER DUCT WORK. HAVE IT CLEANED OUT AND TRY IT AGAIN.
Apr 06, 2008 | Dryers
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Kenmore 64902 Electric Dryer Logo
3,287 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
