Question about Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
Kitchen sprayer stays running and won't shut off
New install 3 moths ago
    Scholar:
  • 68 Answers
From your description it sounds like the sprayer is stuck open. Replace with a new sprayer or rebuild. Higher end faucets rebuild. Lower end faucets replace. Without the Brand or Model# this is my best guess.
Be sure to rate this response and Good luck, Phil
Posted on Dec 26, 2008
My kitchen : !! We have already replaced it with a new sprayer , I think the problem is with the faucet!! The water coming out of the faucet does not shut off and go to the sprayer when in use !!
You need a new spray diverter which is part of the faucet, not the sprayer. What kind of faucet is it? Find the brand, and get the part from plbg supply.
Jun 04, 2017 | Plumbing
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
American Standard Kitchen Faucet Low water flow
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
Oct 31, 2011 | American Standard Kitchen Faucet 6310 020...
Installed new kitchen fauce. no water running though faucet but is running though sprayer. what could be the problem?
Sounds like the diverter that transfer water from faucet to sprayer is bad or stuck. Try turning water off and removing handle and remove spout to acess the diverter is near the base of the body of the faucet. Below is a link with a exploded view that will show you a parts breakdown hope this will help.
http://www.moen.com/shared/pdf/ca87530pt.pdf
Jun 26, 2011 | Moen 87530 Touch Control Single Handle...
I just bought a new Delta kitchen faucet, it is a two handle, sprayer model. It makes a thumping noise when I first turn the water on and when I use the sprayer . I've been told to replace the diverter....
The thump comes from one of several areas. Air pressure in the hand sprayer is one.
But I suspect that you need to check your shut off valves. Old style (non ball) valves fail during this event. There is a little washer that deteriorates, over time....
Then you need to install a faucet, you shut the valves and the little washers either break or come loose. When they break, little pieces go up and clog the faucet.
The other failure is they partially block flow afer coming loose, and cause a thump, like what you describe. To fix, shut off main water in the house and DRAIN what you can. Best to replace with whole new valve, but next best is to replace the guts, unscrew and take to hardware store and get new stem and guts. Inspect the seat, often they get damaged and pitted. Nor necessarily an issue on this install, as the valve in normally open...
Oct 17, 2010 | Delta Home
Installed Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD a couple months ago. About a couple weeks ago experienced low flow for about 4 hours then started working fine. Now...
Remove spay head from the end of the sprayer hose and turn the water on. If you have good pressure without the head, call Delta and ask for a new spray head. If you still have low water pressure without the spray head attached, call Delta and ask for a new ceramic disc cartridge free.
Sep 01, 2010 | Delta 16955-SSSD Stainless Steel Victorian...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 | Plumbing
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
719 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
