Question about Lakewood 792/JR Utility Heater
Lakewood 792/JR heater running w/o heat
I have purchased several Lakewood 792/JR portable heaters and when new, they work fine. However, after about 1 year, they quit producing heat. I don't want to keep replacing the whole heater ... even though they're only $20-25 ... every year. Is there something that can be purchased locally and replaced that will restore the heat? Thanks, Michael
  • movie_gals Feb 16, 2009
    Maybe same problem. with my 792JR. Light comes on at the switch indicator, but fan won't turn, & there is no heat. Perhaps someone can help? Thanks.
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Posted on Apr 22, 2007
  • Brig97 Dec 31, 2010
    Is there a identification part number for this fuse link? Where can it be purchased? Possibly at Radio Shack?
    Dean: Brig97@aol.com
Only use the heater on the 750 watt setting and it runs for years no problems:')
adelpit346
Posted on Nov 15, 2009
Got a lakewood heater jr 762 and the switch is burned out. Where do I got to find the replacement, or what's the part number? Thanks
I would assume you are talking about the thermostat switch. These switches are very simple to repair on your own. They are open without any housings and can be accesses by generally removing the panel from the heater. These thermostats fail at the two contact points due to the consistent arcing from opening and closing or on and off. These arcs create carbon buildup which then will not allow them to make the continuity necessary to turn the heater on. In some cases they may even fuse together keeping the heat source consistently running. If the heat source is continuously running with a faulty thermostat the thermal fuse may fault out. If the thermal fuse faults the fan may work but the heat source will not. These fuses will need replaced by an experienced person, you can generally pick these up on ebay for a few dollars. For carbon build up use a small wire brush to remove, while using fine sandpaper to drag between the contact points of the thermostat. Good luck. Mike
Apr 15, 2011 | Lakewood 792/JR Utility Heater
Lakewood Model 792/A My heater has stopped working. The light indicates that it is receiving power. I checked the tip switch to see if stuck open. OK Next step please? Jeff
Separate the case and trace out the wiring you are looking for an over heat limit switch. These are usually at the top of the case. You should also go over the element with a volt ohm meter make sure it is good, once you locate the thermal overload check it with the volt ohm meter it should read closed or dead short. If it reads open here is your culprit. It has been my observation that replacement parts can generally cost as much as replacing the entire heater. These I can pick up all day long for $19.00 at Home Depot the call them milk house heaters. Good luck with the repair.
Dec 28, 2010 | Lakewood 792/JR Utility Heater
Where can I get a replacement thermostat for a Lakewood 792/JR space heater?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Nov 06, 2010 | Lakewood 792/JR Utility Heater
What to do if my lakewood 729 jr utility heater wont come on it on ly glows
sounds like your fan is not turning you may need to unplug and try to move the fan motor by hand this may take a few tools to open the unit and see if its stuck if it is try sprayin the motor shaft with wd if ti turns by hand
Apr 09, 2010 | Lakewood 792/JR Utility Heater
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Hello, I have a Lakewood space heater, Model # 792/JR, and one of my kids tried to dry her shirt by placing it over the heater and now it comes on but doesnt heat up. Can this be fixed?
The heater "over-heated". It's supposed to have a safety cut-out. The question is, can it reset itself? If there is no manual reset button on it, leave it unplugged for 30 minutes or so. If it still doesn't work, spend $20 on a new one.
Jan 19, 2010 | Lakewood Engineering&Manufacturing PHT150...
Lakewood heater 792/AA Fan works and pushes warm air, but element/coils never heat up where heater actually gets hot.
sounds like a broken element or wire. with unit unplugged, using an ohm meter check all connections and check elements for resistance.
Jan 13, 2010 | Lakewood 792/c Utility Heater
LAKEWOOD HEATER DOESENT HEAT UP
take it apart they should be aglass fuse inside
Dec 24, 2009 | Lakewood 792/JR Utility Heater
Lakewood 792/JR Utility Heater Logo
1,134 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Paul Carew
Steve Allison
Steve Allison
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
