Question about Acer Aspire 3000 Notebook
Acer aspire 3000 dropped on floor. Random startup events
The laptop hit the floor hard. turned laptop on. got to acer splash screen. froze. turned off(held power button for 4 seconds). turned on again.. black screen. only visible on is power button. turned off and on and got random results up to and including: see desktop goto start menu. Locks up. get as far as screen asking how to startup(normal,safemode) locks up. choose safe mode. locks up. 5 times in a row black screen only. wait 5 min while typing this message,get to acer splash screen, choose start windows manually, get to windows splash screen, scandisk, 86 percent completed...... locked up.... can't even use the fn keys to make screen go dim..... The only consistent symptom is that after it locks up, it continues to lock up for every reset unless I let it sit for a bit............ fan cooling on startup
  • 60 Answers
It definetly soundas like Hard Drive failure as previosly said. the hard drives are inexpensive so just look for a 2.5" hdd and away you go.
Posted on Apr 16, 2007
    President:
  • 2,961 Answers
Theres a good chance that the hard drive platletes and parking head have been damaged, although this is not a huge problem to replace, as long as your screen is working ok, then it is worth replacing. you can access it on the underside of the casing, in the largest compartment, remove all screws and the hard drive will be held in with more screws.
Posted on Apr 14, 2007
How do I fix / replace a cracked screen on Acer Aspire V5 - 571 LAPTOP
Take a look on Amazon for the screen and then google the term "disassemble Acer Aspire V5-571P. There are most likely videos showing how to do this.
May 16, 2015 | Acer Computers & Internet
How can i getthe bios for may acer aspire one series model zg5
Things You'll Need:
  • Acer Aspire laptop
  1. 1
    Click the "Start" button found at the bottom left hand side of your desktop. Select "Turn Off Computer" in the "Start" menu options.
  2. 2
    Click "Restart" in the "Turn Off Computer" dialog box to reboot your computer.
  3. 3
    Watch your computer's reboot display closely. Press "F2" when you see the system keys display at the bottom of the screen, just before the Windows splash screen appears, to access the BIOS panel.
  4. 4
    Make any needed changes in the BIOS and hit the "F10" key to save your changes and exit the BIOS. Your computer will complete the startup process and launch Windows.
Read more: How to Access an Acer Aspire BIOS ' eHow.com http://www.ehow.com/how_5809235_access-acer-aspire-bios.html#ixzz1E2WkwLWf
Feb 15, 2011 | Acer Aspire One PC Notebook
Acer 3000 Series Laptop Splash screen does not appear at startup when pressing F2 on the post page. Therefore unable to acces bios. Has e-manager but cannot access bios through it either. Welcome all...
It sounds like the Acer logo has been turned off in the bios settings. As soon as you hit the power button, start tapping the F2 key until you see the test appear "entering setup". Once you are in the BIOS, look for the Logo settings as far as being visible during Boot up. I've seen this setting on other systems so I am thinking the Acer should be similiar.
Jun 19, 2010 | Acer Aspire 3000 Notebook
Black screen on Acer 4720Z
If your booting to the splash screen ( ACER Logo screen ) then it goes black reboot - access the bios and do a bios hdd test - you mostlily find your hdd has died. Head scrash
Mar 07, 2009 | Acer Aspire 3690-2196 Notebook
Acer aspire t135 rebooting problem at startup constantly
I am assuming that it starts up, goes to the windows splash screen, the reboots and starts the whole process again?
Try to boot into safe mode: When you see the first screen, hit the F8 Key repeatedly, which should bring up a menu of boot options. Choose the safe mode option, and hit enter. If it boots into safe mode, I would start by running a checkdisk on the hard drive. Here's how:
Hit the Windows key and the letter R, in the prompt that comes up type in cmd and hit enter.
This should bring up the console. type in chkdsk /r/f in the prompt. It should say the drive is locked, and ask if you want to run on the next startup. Type y and enter. Then reboot. The checkdisk should run, and may be able to recover any bad sectors it finds. If it finds lots of problems, a more thorough diagnostic should probably be done, as the hard drive may be failing.
Jan 01, 2009 | Acer Aspire T135 PC Desktop
My Acer Aspire 3000 has a blank screen
I suggest you check the settings of your bios. Normally this happens if your Hard drive is unreadable. Change the settings of the boot function to first boot on Hard disk and try to disable all other bootable hardwares like CD or network card.
Hope this helps.
Apr 22, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3620 reformatting
You can download your driver here: http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
Just enter the model number of your stuff to driver list in PDF.
Jan 03, 2008 | Acer Aspire 3000 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5100
This is a duplicate posting, the main discussion can be found here: http://www.fixya.com/support/t133152-acer_aspire_5100
Feb 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
234 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
