Question about Frigidaire ATF6000ES Front Load Washer
WHAT DOES ERROR CODE 10 MEAN/FOR FRIDGIDARE FT.load washer
Can you tell me what error code 10 means,the pump is not clogged,the lines are clear and the water pressure i up. thank you merry x-mas
  • Anonymous May 03, 2009
    I get E10 error code on my FT loader washer. what does it mean?
The E10 error indicates a long fill error, meaning the machine thinks it took to long to fill with water.
Recommend you check that the drain tube is not stuck too far into the stand pipe possibly causing a siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow. You can hook the drain hose off, force water through it with a water hose, unclog the stinky mess and hook it back up again and work it.. that would do it...
Posted on Apr 12, 2009
  • 15,935 Answers
What does error code IE mean?
The "IE" error code indicates that there is a water inlet problem on an LG washing machine. This code appear's if the washer will not fill to the correct water level. There are 3 possible causes for the IE code.
1) partially or fully closed water supply lines
2) improperly attached supply hoses
3) clogged supply hose filters (on machine and in the hoses).
Nov 20, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Hello, My L G washing machine has an error code OE... what does that mean?
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Oct 20, 2014 | LG WM-2277HW Front Load Washer
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Have a Maytag washer MAH8700AWW, I keep getting ND messag. Replaced water pump and machine still behave the same.
Hello, You may have not have had to replace the pump in all actuality. The ND error code can be caused by anything caught in the entire drain area which means from the port hole that comes out of the outter tub you would need to remove the hose that connects to this spot and then to the pump. Also you would remove the drain line after the pump as well and assure in both areas that there are no obstructions. If you still have the ND error code after you have assured you have no blockage in either of the above mentioned areas message me back for further diagnosis. Also after you clear the clogged area make sure you unplug the unit for 7-10 minutes this causes the control to reset which is easier then you haveing to go into diagnositic and clear the error code. I await your reply Thanks Rick
Aug 27, 2011 | Maytag MAH8700A Front Load Washer
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
What does error num. F02 mean?
"F02" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In MOST cases, this simply means you have something clogged in the drain pump and the pump requires cleaning. However, if the pump becomes damaged and no longer pumps at the correct volume, the error code will reappear. In this case, the drain pump will require replacement.
If you perform these steps and can't get the error code to clear, please post back and let me know. I hope this helps you.
Aug 04, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Wont drain f21 and 5d codes
"F21" is a Long Drain error code. This generally means you have a clog somewhere in the drainage system. In particular, the drain pump or drain lines. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
This problem is usually corrected by checking and cleaning out the drain pump reservoir. If you clean out the drain pump and the verify the drain lines are clear (including the drain line from the bottom of the wash tub to the inlet side of the drain pump) and the problem still persists, the drain pump my be damaged. If this is the case, you will need to replace the pump.
NOTE: The other error code may be "Sd" which is a Suds detect error. This error can appear in conjunction with the other error code if the pump is not functioning, or is clogged, and air is detected in the pump. More than likely, this code will disappear when the drain problem is resolved.
If you have any questions, please let me know. I hope this helps you.
Jul 14, 2009 | Kenmore Elite 45986 Front Load Washer
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
530 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
