self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Hello there: Just to clarify if yu are talking about the entire oven not working than check out these solutions Fuse/circuit breakerCheck
to see if power is getting to the range/oven. Does anything turn
on--even a light? If not, check for a blown fuse or tripped circuit
breaker.Main wiringOften
the main wiring connection from the house, at the range/oven, gets
burned and so breaks the connection. Then you may have to replace the
power cord to the range/oven, and the terminal block that the wire is
attached to.Range/oven wiringThere
may be a broken or burned wire at the back of the range/oven. If you
repair any of the wires, use only proper appliance-grade wire and wire
connectors.HOWEVER IF IT WILL NOT BAKE OR BROIL It won't bake or broilIf
neither the bake nor the broiler heating elements heat, but the range
burners still work, the clock may be set for a timed or self-cleaning
cycle. Check to be sure the clock buttons and knobs are set properly. If
your clock has a knob that says "push for man(ual)", push the knob in
and try the baking and broiling elements again. If it still does not
operate properly, you probably have a defect in the thermostat, selector
switch, or common wiring. If
the oven does not have a separate bake/broil/etc. selector switch, the
problem may be with the thermostat. But it's not easy to check the
selector switch or thermostat for proper operation. If you suspect a
problem in this area, call a qualified appliance repair technician.
Hello there Please read the entire solution i have provided below ok It won't bake or broilIf
neither the oven nor the broiler heats, but the range burners still
work, the clock may be set for a timed or self-cleaning cycle. Check to
be sure the clock buttons and knobs are set properly. If your clock has a
knob that says "push for man(ual)," push the knob in and try heating
the oven and broiler again. If they still don't work properly, you
probably have a defect in the thermostat, selector switch, or common
wiring. Note...
If the oven doesn't have a separate bake/broil/etc. selector switch,
the problem is often with the thermostat. It's not easy to check the
problem with either of these, call a qualified appliance repair
technician.
Hello there: first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you . It won't bake or broilIf neither the bake nor the broiler heating
elements heat, but the range burners still work, the clock may be set
for a timed or self-cleaning cycle. Check to be sure the clock buttons
and knobs are set properly. If your clock has a knob that says "push for
man(ual)", push the knob in and try the baking and broiling elements
again. If it still does not operate properly, you probably have a defect
in the thermostat, selector switch, or common wiring. If the oven does not have a separate
bake/broil/etc. selector switch, the problem may be with the thermostat.
But it's not easy to check the selector switch or thermostat for proper
operation. If you suspect a problem in this area, call a qualified
Hi Thanks for using FixYa. If
neither the bake nor the broiler heating elements heat, but the range burners
still works, the clock may be set for a timed or self-cleaning cycle. Check to
be sure the clock buttons and knobs are set properly. If your clock has a knob
that says "push for manual", push the knob in and try the baking and
broiling elements again. If it still does not operate properly, you probably
have a defect in the thermostat, selector switch, or common wiring. If the oven
does not have a separate bake/broil/etc. selector switch, the problem may be
with the thermostat. But it's not easy to check the selector switch or
thermostat for proper operation. If you suspect a problem in this area, call a
qualified appliance repair technician. Please do accept the solution
if the issue is resolved or else revert for further assistance. Thanks Rylee
If
If your clock has a knob that says "push for man(ual)", push the knob
in and try the baking and broiling elements again. If it still does not
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
I have the digital timer oven and also cannot find the manual. You have to set the bake time timer, I think for 3 hours. Then you set the oven knob on clean and turn on the temp knob, probably to full but I don't think it matters. When you engage the lock, the clean light should come on/ When the oven reaches high temp, the lock light will also be on.
