Question about GE JE1160 Microwave Oven
GE Profile Spacemaker 2.0 does not heat up food
Microwave (model JVM2070SH01), works fine, just won't heat up food. A couple of days ago, machine prompted us to order and prepare to replace the filter, but before I could order it, the machine made a loud sound 2-3x. One day later (today), it is not heating up. What can I do to resolve this?
  • Anonymous Jan 28, 2009
    I have the same problem. Light, turntable turns on and I assume cooling fan is on also. It's hard to tell because it is now louder than usual.
    Is this a high voltage problem? Is it easy to fix?
    I have a white GE spacemaker model # JVM1630WB-002.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light, cooling fan and turntable come on?
    When I say internal
    cooling fan, I do not mean the hood vent exhaust fan which you can turn
    on and off manually.
    I'm instead talking
    about the internal fan which comes on automatically whenever you
    microwave.
    Any unusual noises? Is
    it louder or quieter than usual?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker® XL1800 Microwave Oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
SOURCE: ge profile spacemaker XL 1800 undercabnet microwave
Home depot sells the lights as I believe reffigeratro bulds. bring the old ones with you to match them up. i got a price from an appliance parts place of $40. The depot was like $6.
Posted on May 08, 2008
Illeagle
  • 525 Answers
SOURCE: GE Profile Spacemaker II - Burning smell and no heating
You may have a failure of the H.V. rectifier. I would recommend that a trained technician replace this part due to the high voltage potential.
Posted on Jun 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker Microwave - won't heat
Thanks for making your post very detailed and including the model number. That really helps! :)
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly easy & cheap do-it-yourself fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 13, 2008
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker LX1800 that is not heating up the food. It acts like it was working normal but is not heating the food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]---=]
May 11, 2010 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker Microwave #JVM1650WB008 is not heating.
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MIcrowave doesn't heat up food
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1160 Microwave Oven Logo
416 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
