Question about Kenmore 24032\24036 Top Load Washer
2 year old top loader Kenmore fills, washes, doesn't drain & does
Filled with water...the center post will girate, but the tub will not spin. Is this a belt issue or a motor issue? How do I fix it?
Jill
  • jillbenge Dec 28, 2008
    Lid closes & kid switch clicks. Any other suggestions.
  • 640 Answers
Check yor lid switch,,its a little switch on right side of cabnit..listen for a click,,your unit doesnt have a belt it has coupling
Posted on Dec 25, 2008
  • onthethejob1
    onthethejob1 Dec 28, 2008
    ok im here we wi get you working,,now does unit wash ,,i want you to put it on a smal fill cycle and watch..to see if it will wash,,
Kenmore washer doesn't totally drain is this normal?
depends, all washers will have water in them at all times that you can hear if you move the tub , if you see the water there is a problem. If you see water then you have a restriction in your drain pump or your drain hose could be siphoning water back into the unit when it is spinning . now this all depends on your washer type.
Feb 17, 2013 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore Elite Front Loader
Debris can be in the fill valve, jamming it open a little. You can't always take them apart. Turn the water off at the faucet to check. Get new hoses, the filters in the old ones must be bad, and old hoses can blow.
May 10, 2009 | Kenmore 44102 Front Load Washer
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Kenmore 110.24422300 Top Loader Washing Machine
We have one of two situations happening here. Either your timer is going or the motor is blown. The other thing is to put the machine into spin and see if it drains, let me know!
Oct 02, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub. culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Jun 10, 2007 | Kenmore 20172 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
