Question about Pure Digital Flip Video Camcorder
Dropped in ocean. Can I recover the data ? Or video ?
After dropping it in the ocean I rinsed it off with fresh water and dried it. Can I recover the video data ?
  • bumbeee Dec 25, 2008
    how do I get to the SD or Xd card on the Flip ?
  • 15,935 Answers
If the card hasnt been comprimised, yes. most SD and Xd cards are sealed from the elements. do it quickly however. time is of the essence
Posted on Dec 24, 2008
Canon customer
Maybe.
Did you fish it out immediately, removed the batteries, rinsed it in fresh water, then let it dry thoroughly before even thinking about trying to turn it on? If so, it MIGHT work again after being dried. Otherwise you may as well give it a good funeral and get a new camera.
Aug 22, 2014 | Canon PowerShot A560 Digital Camera
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
Tip
How to recover MOST of scratched CD data discs First some tools will be...
How to recover MOST of scratched CD data discs First some tools will be needed:
1. Alcohol 120%
2. UltraISO
3. Windows XP/2000 (not tested on 95/98/me)
3. Small piece of cotton
4. Dry cleaner paper
5. Finally, oil for cooking.
First step - preparing the CD
Get the cotton and drop some water, start cleaning vertically the surface of CD.
Do it 3 times and dry the water with a piece of dry cleaner paper. With a new piece
of cotton, drop some oil for cooking and start to wet the surface like you are
washing the CD with the oil. Dry carefully now. Some particles of oil will stay on the
microsurface of the scrath. It's okay. Seems the oil helps the laser of the CD/DVD driver
to read the surface again. Sure this will work with small unreadable scratchs - some hard
scratchs loose parts of the surface of the CD where we have data and it's lost forever.
But if it is loosed try anyway. Whith this tip 80% of the small scratched CD's coud be
recovered.
on Dec 14, 2009 | Electronics - Others
D600 dropped in ocean
There are innumerable metal parts that can and will corrode. Rinsing salt water and eliminating the effects are not the same thing. Damage to the circuitry from shorts may complicate the problems. if you are looking to solve herd a bag of worms go for it but Nikon is right. Out of curiosity how many projects do you have lying unfinished around your house?
Mar 11, 2014 | Nikon D600 SLR Body Only"
Water damaged
It may have been recoverable, but you damaged it further when you tried to turn it on.
If you had fished it out immediately, removed the batteries, rinsed both camera and batteries in fresh water, and then let everything dry out thoroughly before even thinking about putting the batteries back in and turning it on, the camera MIGHT have worked.
Apparently you just shook it dry and tried to turn it on, right? If that's the case, you may as well give it a good funeral and get a new camera.
Jun 21, 2012 | Canon Cameras
Will SD card still work after dropping camera into salt water
If it wasn't in salt water for very long and you rinsed it in fresh water and then let it dry thoroughly, then yes, the card should still work. However, once you download the pictures from it, I'd consider throwing the card away.
Jun 01, 2012 | Canon Cameras
Water damage
well turn yor phone off. and put it in a bowl of rice, and leave it a day or two. but make sure it has the battery and everything out of it if u can.
May 29, 2012 | LG Cell Phones
My nokia phone fell in water and is not Switching on again
Accidents happen with phones and water but it doesn't always mean that all hope is lost. Below is a brief guide as to what you should do if your phone has been totally immersed in water.
1. Take the phone out of the water as quickly as possible.
2. Do not attempt to switch it on as this may cause further damage.
3. Remove the battery as quickly as you can, also remove the memory and sim cards.
4. If dropped in fresh water dry it off with a towel. If dropped in salt water rinse it thoroughly with fresh water. I know it sounds crazy getting it wet again but salt can cause a lot of internal damage such as corrosion. Again dry with a towel. You may also want to rinse it if you dropped it in a toilet.
5. Place the phone, battery and it's wet accessories in a plastic container (like a lunch box) and completely cover it with uncooked rice, use plenty of it. Again this sounds crazy but rice has desiccating properties that help draw the water out of the phone. Do not place a lid on the container.
6. Place the container somewhere very warm and dry for at least 3 days. An airing cupboard is often the ideal place.
7. Do not use a hair dryer directly on the phone to speed up the process. Too much heat can cause even more damage.
This isn't guaranteed to work but many people have successfully revived their phones and retrieved their data using this method.
Keep in mind that your phone is on borrowed time after you do this. Make it your first priority to retrieve any data that you would like to keep. It may only work for a few minutes, days, weeks, months or it may even last years.
You should monitor the phone carefully during charging. If it gets very hot the battery may be damaged and should be replaced.
After any exposure to water you no longer have a warranty as water damage is not covered. Any insurance policies on the phone may also be voided unless you are covered for accidental damage.
A more efficient alternative to rice is silica gel. You most likely won't have enough of the stuff to hand when the accident happens but it is good to use. Silica gel can be bought from electronic wholesalers like this example. Thank you to shuntfield for this information.
Mar 05, 2010 | Cell Phones
Tv remote problem
If you rinsed it in fresh water immediately after the drop then maybe it will work again. You would need to replace the batteries.The prospects are, however, not good. Best to to get a new one.
Nov 07, 2008 | Toshiba 50HX81 50" Rear Projection...
Phone wont turn on
im sorry to be the one to say it, but the phone is gone. i dropped mine in the ocean once and i tried cleansing the phone with distilled water, and then i heated it in the oven (on the lowest setting) to get all the moisture out, i even took out the data chip and tried to hook it up to my computer, but the data was corrupted. Sorry.
Aug 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Pure Digital Flip Video Camcorder Logo
301 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
tomikles
Level 1 Expert
richie46
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
