Question about Insignia Televison & Video
Television vertical overscan
About half an inch to an inch vertical overscan. All I need to know is how to access the vertical lin and height controls.
After I get the vertical solved, I'll go and try to find if there is horizontal overscan as well. If you happen to know where the horizontal size control is (if it even has one) that would be appreciated also.
Insignia NS-24FTV
    Master:
  • Insignia Master
  • 267 Answers
Hello!
Please check the "Troubleshooting" part of the manual to this TV.
https://manualsbrain.com/en/manuals/1874651/?page=24
Posted on Aug 31, 2017
  • 1694 Answers
SOURCE: Horizontal line in the middle of the television
tnewk, Your symptom is no vertical deflection = check for
B+ voltage present at vertical output IC.If present = replace IC.
If missing, check B+ power supply............T.
Note: 10 ohm resistor replacement symptom = No video,
lit white screen with retrace lines ...........T.
Posted on Nov 08, 2007
  • 2337 Answers
SOURCE: need a remote for a
You can find the remote control HERE.
Posted on Mar 16, 2008
SOURCE: Cannot make horizontal and vertical size and position adjustments
OK...I paid a whole $50 for an Apex AT2702 that had [undisclosed] vertical zoom, horizontal shift, vertical shift and width issues. Before I raised hell for the person who sold it to me, I decided to first exhaust all alternative solutions.
I found that in order to tweak these settings, you have to be in service mode and must have a service manual which I can email upon request.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE !!!
1-Reduce your tv volume to 0
2-press the MUTE button on your original tv remote [you'll see "Mute" in red on the screen]
3-AT THE SAME TIME, press MUTE on the same remote and MENU on the tv controls.
This set your tv into service mode [there will be a red "S" at the top-center of your screen.
You'll need the table in the service manual page 47 where there are V-SHIFT, H-SHIFT, V-ZOOM, E/W WIDE default values that will need to be changed. WATCH YOUR SCREEN as you change the values to ensure you don't over do it.
If you have news ticker and sports scores issues, you'll want to be tuned to CNN, FOX, ESPN or whatever to see how your changes are applied.
If you have tv guide problems then tune to that channel or press info and see what happens when you make the changes.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE.
This has worked for my set and you may attempt this solution on yours at your own risk.
I'm no longer pissed off that I got a bogus tv because it now works just fine and I can see everything!
Good Luck!
Posted on May 22, 2008
  • 78 Answers
SOURCE: GE Universal Remote Code for my Insignia DVD Player NS-DVD1
if you have already tried "code search" then you may have to return that remote and get a different name brand of universal remote.
Posted on May 30, 2008
  • 88 Answers
SOURCE: Insignia NS-27HTV
check & replace chroma ic. good luck!
Posted on Jun 13, 2008
Panasonic 42 viera. no remote,and need to turn off overscan. is it possible without the remote?
Only if you can access the menu settings manually. On most new sets the remote is a must for certain functions such as this one.
Sep 29, 2016 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Overscan
Yes, if you have the original remote and get into the adjustment menu which is hidden you can adjust width, height, and centering if you want.
Dec 09, 2012 | Mitsubishi VS-50111 50" Rear Projection...
I have cable input and the picture is a little to big for the screen and it chops of some of the top of the picture
if using a box for signal some have adjustments for this and if not the issue is in the set---vertical height or Lin.
May 01, 2012 | GE D52GW12 52" Rear Projection HDTV-Ready...
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Vertical height adjustment on Magnavox 19 inch LCD HDTV
try to adjust at the vertical section.hope this will help
Feb 01, 2008 | Philips 19MF337B/27 19 in. LCD Television
Overscan
For Factory Menu, press MENU 1 3 7 0
Service Adjustment Mode, press MENU 2 3 5 7
Convergence Mode, press MENU 2 3 5 9
Use the VIDEO or VIDEO buttons to enter two different groups of adjustments
Use the VIDEO / VIDEO buttons to toggle thru the adjustments
Use the + and - keys to adjust
When finished with adjustments, press ENTER to save
Press MENU twice to exit service mode
Hope this helps. You should look for the vertical height or size adjustment. Do not adjust anything you don't know about.
Dec 28, 2007 | Mitsubishi WS-65313 65" Rear Projection...
Zenith Z27X22D Service Menu Codes needed
significant vertical overscan. It is such that it's impossible to read crawls and such at the bottom of the screen. I think this problem is a tv problem. it is due to vertical section. please change electrolytic capacitor in vertical output section. it will be ok. it is common problem can be fixed at home & very simple.
Oct 03, 2007 | Zenith Z27X22D 27" TV
Televison & Video Logo
117 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
