Question about Ariens 34 In. Zoom Series Riding Mower
Brand new Ariens ST624e seized after 15 minutes of operation?
I bought a new Ariens Model 920001 snow thrower at Home Depot a couple of months ago. At the time I assembled it and "ran it in" for 15 minutes as per the manual and everything seemed fine. A couple of days ago I needed to to use it and when I pulled the recoil starter it started right away but stalled out after a few seconds. I pulled the starter again and it ran about two seconds and then stopped. The next time I pulled the starter the motor could not be turned. I checked the oil level and it was okay. Suspecting the recoil starter I removed it but that wasn't the problem. I removed the spark plug and it looked soaked in oil. The motor still wouldn't turn with the spark plug out.
I had added gas stabilizer to the fuel when I filled it for the first time.
Any idea what could have gone wrong?
Thanks in advance for any suggestions.
  • 15,935 Answers
If there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Posted on Dec 24, 2008
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
!332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Oct 07, 2009 | Garden
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Ariens 34 In. Zoom Series Riding Mower Logo
532 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
