Question about Yahoo Messenger
I CAN SEE THEM, BUT CAN'T HEAR THEM. THEY CAN SEE AND HEAR ME
I've checked my audio and speaker levels - they seem ok. Maybe I'm missing something.
  • 238 Answers
Try downloading audio codec and install it.
Posted on Dec 25, 2008
NO SOUND FROM MY COMPUTER
Check the Mute button make sure it is not selected, also check the volume level,move the volume setting higher or to max.
Check the audio chip is OK by plugging headphones into the audio out/headphone socket.
If it is OK then most likely the speakers are faulty and they need to be replaced.
Mar 15, 2013 | Computers & Internet
External speaker do not work
Follow these steps: Go to the Control Panel > Hardware and Sound > Sound > Manage Audio Devices under the Playback tab, select "Speakers" or any playback device listed. double click the device or click Properties. Go to Levels tab. Under the "Speakers" and "PC Speaker" area, adjust the volume level to its maximum. Then apply changes.
If the above instructions wont work, try this out:
Check if your speaker is detected when you plug it in.
If it isn't detected then either your sound drive has a problem/missing or maybe somethings wrong with your computer's headphone/speaker jack.
If detected, set it as your default device.
Hope it helped! :)
Jul 27, 2011 | Computers & Internet
I can not figure out how to adjust the balance on my speakers. It seems that one speaker in louder than the other. I cant find my manual and i've been tinkering with the receiver with no avail.
Tinkering won't work. HT510??? Not HTR510? Maybe that's what you meant.
All AVR's have settings for individual speaker channel levels and distances from the listening position.
http://filedepot.onkyousa.com/Files/own_manuals/HT-R510.pdf
Jul 11, 2011 | Onkyo HT510 Receiver
Hi Thanks for your help, One year old Sony mini
sir i think ypur unit is ok and run correctly... try to check your speaker maybe your speaker got open or burnt... you can test it by swapping your speaker to another unit or you can test your speaker using multitester...just point your selector at resistance test a speaker has 8ohms reading....
the speaker has a two terminal.. a positive terminal and a negative terminal... your multitester has a two lead.. red lead which is a positive and a black lead which is negative..
measure-speaker-impedance-1.1-800x800.jpg Multimeter probe sockets (NL Graphics) Insert the probes of a digital multimeter in the correct sockets of the multimeter. There may be several different sockets for the probes depending on what parameters you're measuring. Look for the sockets marked "impedance" or displaying the ohm symbol. Different models and brands of multimeters will vary in their labeling, so check your multimeter's manual if you're not certain about which one to use.
  • 2 Select the range for the multimeter. Since you'll be measuring fairly low resistance levels with a speaker, choose a range that will encompass readings in the 2-16 ohm range. It's extremely rare to find speakers that will have an impedance outside of that range.
  • 3 Touch one probe to each of the speaker terminals and check the reading. This will be the impedance of the speaker. Record the measurement, and when you're done, turn off the multimeter to preserve the batteries for the next time you need the multimeter.
  • Read more: How to Measure Speaker Impedance ' eHow.com http://www.ehow.com/how_5068180_measure-speaker-impedance.html#ixzz1OsNOPSq3
    if you think this help please rate me thanks...
    Jun 10, 2011 | Sony CMT-HPZ9 Shelf System
    MSI K9N6PGM2-V2 motherboard audio VERY quiet.. I can't tune the volume very loud at all. The board is brand new. I can hear the audio from the external speakers when volumes are set to highest levels...
    Check to make sure the following:
    • You have the speakers plugged into the 'green'-colored sound connectors at the back of the mobo.
    • Also make sure that your 'Windows Sounds' aren't set low. Sometimes I set my Sound Properties (accessible when you double-click the speaker icon in the taskbar) to 'lose' that setting, to keep things simple. But if your overall volume is at 100%, and this setting is at around 20% or below, you could experience this issue.
    • If these are not powered speakers, you know what I'm saying here...
    I'll check back in later to see if this helped you. Mike
    Feb 27, 2011 | MSI K9N6PGM2-V2 Motherboard
    Bass problems
    At the audio mixer settings choose playback and look for something like "for advanced users" or like that. Here you will find the BASS - TREBLE control. In some older audio cards there isn't any selection like that.
    Stelios.
    Feb 20, 2010 | Inland ProSound 2000 Computer Speakers
    My chatmate can hear me but i can hear her
    might be ur speaker is not intgrated with mic give it for service
    Dec 22, 2009 | Yahoo Messenger
    The right speaker on my Bose Companion 3 works for a while then just stops working. I haven't changed anything on my computer setup. I checked and the plugs are inserted tightly.
    Can you hear anything from it right now, such as scratching noise or something, if you can hear something, then check the audio input cables, or the output to the right speaker, try turning it or something.
    If that method didn't works, then possibly there's two conditions:
    1. Your right speakers burned, try replacing it with the new ones.
    2. Your power board half damaged, the right channel is damaged or something.Maybe the IC's burned or maybe just some minor electronics parts that is not working properly.
    Dec 09, 2009 | Bose Companion 3 Computer Speakers
    Mic. on Logitech Communicate MP doesn't seem to work - people at other end cannot hear me
    Set up Audio example
    Laptop x webcam/mic x Vista x Yahoo Messenger
    If you have an earlier OS, you may have to access your hardware from the Control Panel.
    TEST SPEAKERS
    Right click on speaker icon in System Tray
    Select "Playback Devices"
    The speaker icon ( checked as working) and volume level graph should be visible
    Right click on the volume graph and click "Test"
    Left hand speakers followed by right hand should be heard
    SET DEFAULT & TEST MIC
    Click "Recording" tab.
    To set required mic as default - click on mic font to highlight and click "Properties"
    In lower dropbox display "Use this device enable" click OK
    Click "Levels" tab and ramp up sliders ( adjust to suit later)
    Return to "Recording". Test mic by speaking and make sure volume graph displays
    Restart computer
    CONFIGURE TO MESSENGER
    Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
    make sure your internet connection and country are correct in the lower two boxes > Apply > OK
    Click ( > ) Messenger > Preferences > Calling and Audio
    Set mic and speakers to show Default equipment
    Run call up assistant to test audio equipment > Apply > OK
    Dec 07, 2009 | Logitech Webcam
    No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
    Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
    Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
    Yahoo Messenger Logo
    57 people viewed this question
    Top Yahoo Computers & Internet Experts
    micky dee
    Mike
    Sunday Ojelabi
    Sunday Ojelabi
    Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
