Question about T-Mobile MDA
T-mobile MDA on/off switch broken
The on/off switch on my t-mobile MDA is broken. It does not have the nice spring loaded click effect, and no longer turns the phone on and off. For a couple days, I could use the phone only after someone called, and woke the phone up. Then, like a fool, I tried removing the battery and putting it back in. Now I can't turn the phone on... :-) How do I disassemble or take apart the phone completely to get to the switch? Any ideas on how to repair the on/off switch? Thanks.
  • serge67 Nov 12, 2007
    Not the samed problem but for me it's a LCD creen problem.
    Any ideau how to repair it myself, i looked the link but doesn't seems to wotk.
    Thank's
  • brokemyphone Aug 02, 2008
    I dropped my MDA and knocked the spring loose, I also took the battery out, and now im stuck with a dead phone...
Plug in your charger to your phone, find something small to stick into the reseting hole, when your phone turns on, go into settings>power>advanced: un-click the "turn off device if not used for"
it may drain your battery faster, BUT it works!!! :D
Good Luck!
Posted on Aug 02, 2008
I cant go to that website?
Posted on Nov 22, 2007
Here is the service manual for the T-mobile MDA (aka Wizard):
ftp://xda:xda@ftp.xda-developers.com/Uploads/Wizard/Wizard_Service_Manual.pdf
Posted on Nov 05, 2007
  • 76 Answers
You need to use a torque 6 screwdriver to loosen the screws under the battery. Ther are also some screws by the camera.
Posted on Sep 25, 2007
Ignition switch does not load any longer...
it sounds like the ignition switch that the key goes into is bad. that is replaceable.
Apr 10, 2016 | Cars & Trucks
My pc is not detecting my T-Mobile MDA
in windows, right click on the CD player with you cd in it.
click explore and look for USB Drivers.
Install the drivers and try hooking your phone up again.
Try using a fast USB 2.0 port on the computer.
If this helps please leave a vote
May 13, 2009 | T-Mobile MDA Vario Smartphone
No bluetooth hardware on t-mobile mda
dear u need to reinstall ur OS on ur MDA it will automatically install ur blue tooth device drive..there is no possiblity that in MDA blue tooth wont present...so go to start>> setting >> clear Storage...and then wait for ur OS to install automatically...but remove ur storage card and also backup of ur data (device data) or copy it to storage card...it will work..
Feb 17, 2009 | T-Mobile MDA
T-Mobile vario
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
Jan 18, 2008 | T-Mobile MDA Vario Smartphone
MDA 3 dead
If a device fails during a rom upgrade its as good as dead because it doesn't have enough instruction to start the process over.
Jan 17, 2008 | T-Mobile MDA
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
Priblem in starting T-Mobile MDA Pro
Try to remove the Micro SD card from your MDA
Jan 11, 2008 | T-Mobile MDA Pro Smartphone
T-Mobile MDA clock
Simply Tap and hold the analog clock and a menu will appear, letting you choose to switch to digital.
Sep 27, 2007 | T-Mobile MDA
Want manual in eglish language forT-Mobile MDA III (PH20B, HTC Blue angel)
Go to this link and click "user manual" and there are a selection depending which software version you are running; http://support.t-mobile.com/main.html?formFlow=manufacturerForm&tree=null&selectProductDevice=8802DDEB-1EE4-477A-9608-D9CD1E2A903F&selectProductManufacturer=_bc51c48e-e7ce-411e-86d7-40b52cf362eb Hope this helps :)
Mar 18, 2007 | T-Mobile MDA III Pocket PC
Pda network unlock
visit howardforums.com and search for the solution to cid/sim unlock the mda.
Jan 15, 2007 | T-Mobile MDA
T-Mobile MDA Logo
280 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
