Question about Zoeller Electrical Supplies
My pump does not shut off when the float switch goes down
The pump works but it is always on, and does not respond to the float switch that is connected to the top of the pump.
  • 3 Answers
Good Morning -
I had the same problem with a freind's pump that used a free floating pump switch, first of all the sumpump hole was just barely large enough to accomadate a sump pump, I removed that pump and installed a sumpump that hat a short float connected to the top and bottom of the pump housing and my friend has had no problem.
I did build a short device to make sure the pump as'y stayed in that corner out of 2"pvc.
have a great day!!
TNmec
Posted on Jan 05, 2009
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Whilpool gu2300xt,wash cycle lights wont light,when i push start button goeswt calcell and drain and you can here drain pump then it shuts off
It is likely there is some fault with the float switch. Which means the dishwasher thinks it is overfilled with water and tries to empty out to protect itself. This is why the pump turns on as soon as you try to run the dishwasher. Refer diagram. You need to check if the float (12) spring is responding by pressing it down and checking if it comes up. Also level switch could be faulty.
Jan 12, 2013 | Whirlpool Gold 24" Tall Tub Built-In...
Pump will not shut off even when water level is down.
the float switch is getting hung up,first try to clean off the float switch ,shkae it like a rattle you should here it move inside, if that does not work relace it
Jun 10, 2011 | Zoeller M211 Automatic Aqua-Mate...
Our engine bilge pump is almost inaccessible but I can just about reach it. Lifting the float switch the pump doesn't work but using a switch at the helm the pump works. Is there something I can do...
Hi, if you can switch on the pump, it's OK. Usually, the pump needs the helm switch on AND the float up. Does the pump not shut off when you push the float down? That would be normal operation, unless the helm switch has both automatic and manual settings.
Apr 04, 2011 | Rule A-Matic Float Switch
Taking a shower the pump goes on an off constantly,is it not suppose to fill the tank up first then discharge the water?
Yes it is suppose to fill tank nearly full then pump down and shut off. I would check to make sure that the float switch is not hanging up on something or perhaps rubbing on the tank wall that is stopping the pump from running long enough to empty tank.
Check the placement of pump and float to make sure they are not hitting on anything. Adjust float as needed to allow for max pump down. Also make sure that there is a check valve installed in discharge line so that any discharge can not run back into tank when pump shuts off. Hope this helps you. Thanks
Jan 05, 2011 | Saniflo & Saniplus& Macerator Pump
The high level water alarm intermittently beeps and the pump starts and stops several times before clearing out the water
On the controls to the pump there is a float, or 2 floats that control wheather the pump is on, or off. I don't know wheather this one has one float or 2 so i will give a short explanation for either fix.
Little giant usually has 1 float on a length of cord, or 1 float with a rigid frame that it goes inside, or has a guide rod. No matter which system is employed there is a built in dead band for the interval between when the pump turns on at a high level, and when it shuts off at a low level. If the float is on a rod, or in a cage it needs to be able to move freely. There is a method to control the turn on height, and the turn off height with some little clamps that connect to the switch. So when the liquid level gets high the pump turns on, and then when the liquid level gets to the lower limit the pump automatically shuts off. If these little keepers are right near the top of the float, and right near the bottom of the float then as soon as the pump turns on the liquid level drops just a bit, and the dead band is real small, so it just shuts right off. the liquid flows backward through the pump and then it turns back on, ect... If this is the case move the adjustments that surround the float. Presto.
If it has a little float on a cord then the adjustment for the level needs to be secured to the discharge pipe or something. It has a mercury switch inside the float to turn it on, and probably another to turn it back off when the float goes to a desired level just above the suction at the base of the pump. I would use black zip tie's to hold the cord so that the desired "turn on the pump level", and the propper "turn off the pump level" are what you want. Just hold the cord against the discharge pipe so that the float is above the suction opening to the pump, and the strait up level of the float are what you want.
If it has 2 floats on cords then one of the floats will turn the pump on if both are held upright by the liquid level. This float must be the top float that is mounted on the discharge pipe. If the 2 floats are mounted in the reverse position then the pump will cycle quickly. There will be a nearly nonexisting dead band. Both will be upright but the control circuit will shut the pump off when the top float, which should be on the bottom, lowers even slightly. Use the same method as perscribed above to attach the floats. The one that belongs on the bottom, the one that turns the pump off, should be placed so that the pump will shut off before it tries to pump air. the top float will turn the pump on if it and the lower float are both upright.
Presto.
Oct 27, 2010 | Little Giant TSW-SP-C 45 GPM - TSW Sump...
This is happening to me, too: Model # VCMA-15ULS condensate removal pump switch suddenly began working backwards - it will go on when the float is down and shut off when the float goes up. What is the...
The switch goes bad and that happens sometimes...
I guess you could change the switch but for the price of a new one it isn't worth my time... I junk em and throw a new one in...
heatman101
Sep 17, 2010 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
The dishwasher pump will not shut off. Keeps going even after the dishwasher has been emptied of all water. Then the beeping sounds starts and will not shut off.I took it out thinking that I could get to...
depending on the model, your float is off the switch
it is a round piece in either corner, that should float up and down
if you remove your toe kick and look at the bottom of that, you will see where the float comes through it may be off the micro switch telling the machine that the water still has water and should continue to drain, then after you reahc the 2 minute drain cylce it goes into fault
Oct 21, 2009 | Dishwashers
Electrical Supplies Logo
994 people viewed this question
Top Zoeller Electrical Supplies Experts
Craig Butler
Craig Butler
TEKUSER
TEKUSER
Are you a Zoeller Electrical Supply Expert? Answer questions, earn points and help others
