Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
RCA Projection TV MM52110 Won't Power Up
My RCA 52" MM52110 projection TV will not power up from the remote or from the button on the front of the unit. Based on my internet searches, this is a common problem. How can I fix this myself, since it is not under warranty any longer? I have a friend who is TV-electronics-savvy, but he needs a schematic to be able to troubleshoot it. Where can I get a schematic? I have tried several web sites and they don't have the schematic, since (they tell me) it is only provided to authorized RCA service/repair centers.
  • 5 more comments
  • croomy Dec 16, 2007
    i have the same problem
  • swampyjack Jan 05, 2008
    Sounds just like mine. It will not power up, just comes on, goes off, comes on, goes off @ 4 times. It only stays on a second before going off. I expected better from a unit I paid so much for.
  • Anonymous Feb 10, 2008
    attached power cord to tv ands electrical outlet. tv still will not come on
  • Walkey Feb 24, 2008
    I have the a simiular problem. But I do have a green light tha come on for about, then it shuts off. I did find a circuit board where the TV\cable Ant plugs in to. On this board there is a resitor that has gotten hot enought to start to melt the circuit board. The board number is 1519592k. I was thinking on replaceing the resitor # r25611. but I would think there is a componet ahead of it that might of fail... any suggestions???
  • Anonymous May 16, 2008
    my hdtv is not powering up from the remote nor from the tv bottom i do not know what the problem is but i need help
  • Paul_Hineman Jul 24, 2008
    The unit will not turn on with remote or front of the unit. There is a green light that comes on for about a second and then goes out.
  • Helen Faison Nov 24, 2012
    I have a 50 inch RCA HDTV DLP won't show picture or make sound Power button lights up. that's all
    President:
  • 1,284 Answers
Being able to read a schematic and understanding how a TV works are two different things. These chassis that RCA used in these sets can be somewhat complex to troubleshoot. I would geuess that unless the power light comes on at all then you have a dead power supply in the TV.
Posted on Apr 15, 2007
  • Robert Bonner
    Robert Bonner Jun 06, 2017
    light comes on then whistle goes off then continues again
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
The tv won`t turn on. its it a fuse
Do you mean is it a fuse? Because if the fuse is blown that means more than likely there is something else wrong with it...probably in your power supply. What I recommend is to plug it in and listen for power (high pitched buzz), if you cant hear that...it could be anywhere from a diode to the HOT. If you have an om meter, I suggest checking thos first. What happened before it went out? and are there any LEDs that turn on in the front?
Aug 05, 2010 | RCA MM52110 52" Rear Projection HDTV-Ready...
How can i change the aspect ratio on RCA mm52110. the HD picture is stretched tall but very clear.
I'm going to take a stab at this out of the dark but okay!
1) is there an 'Aspect' or a 'picture size' button on your hand held remote control?
2) If you scroll through your 'On Screen Menu's' do you find a feature that will change the aspect or picture size?
Many of these TV's have this button feature on the remote control.
Blessings,
A/V Media Tech Guy
Dec 03, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Rca mm52110 color is off, and picture is fuzzy
Ur convergence is dead.Get the convergence kit,use what in that kit.U know how to solder right?Tries this websites.Tv Repair World.com Shopjimmy.com or Ebay.com.
Sep 28, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Rca mm52110 rear projection tv with issues
Will power up, but won't have a picture. What could cause this?
Sep 16, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA MM52110 tv
I had a repairman out to look at mine today. He said it was the high voltage protecter kicking off the TV as soon as you turned it on. $400 to $600. to repair.
I love this TV but guess I'll go shopping for another plasma. I have one Plasma TV in the bedroom 50" Samsung (top of the line) it doesn't have as good of a picture as my old RCA.
Jan 31, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA MM52110 FUSE REPLACEMENT
Check on the power supply box. Lower LH corner in back where the plug goes in. There is normally a small breaker switch on it.
Nov 30, 2007 | RCA MM52110 52" Rear Projection HDTV-Ready...
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
628 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
