Question about One For All URC-3021 Remote Control
TOSHIBA CT9954 Sent off for a new remote do not know how to program it Do you need a code then what?
  • 5 Answers
SOURCE: need code to program toshiba tv with Direct tv remote
yry 0154 , 0156 ,0060
Posted on Nov 20, 2007
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Posted on Dec 06, 2008
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Posted on Aug 28, 2009
Puppet03
  • 172 Answers
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Posted on Oct 24, 2009
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
John-INSG
  • 312 Answers
SOURCE: Need toshiba tv set up code for one for all big easy remote controle
If you are in need of remote control codes for a Toshiba TV, I recommend contacting Toshiba directly at 800-631-3811 for further assistance.
Posted on Nov 30, 2011
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
I want to program a universal remote to my Toshiba TV VCR DVD combo TV but I don't know what codes I need
Most universal remotes supply a sheet with the codes you need to program them to your particular make and model. It can take a while to do. If your remote doesn't have the code sheet or your make and model isn't on there, you could try doing a manual search. Not knowing what type of universal remote it is makes it hard to say but usually, there is a manual function that will scroll through every code on the remote until it finds the correct code for your TV.
May 26, 2015 | Toshiba Televison & Video
How to program CT90302 Toshiba remotes aux mode for DVR600 Toshiba
Google the model number of the remote for "manual" which should get you programing instructions and a list of possible codes or contact Toshiba site for same.
Jun 11, 2012 | Televison & Video
I need to know the remote pin code. I have an external converter box with a remote and need to know the number to program the new remote.....please help
Toshiba has 18 codes, they are 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141 0156. Gerald
Sep 09, 2011 | Toshiba 32AF45 32" TV
Need to set my one for all remote to a Toshiba TV?
Try the following codes: Toshiba 0060, 0154, 0156, 1265 . Turn on the TV manually and then press the TV button on the remote. Press and hold Set until the LED blinks twice; then release the button. Enter the four digit code. The LED should blink twice again. Test if the TV turns off by pressing Power once. If it does, check if the other features of the remote control the TV. If it doesn't, try a different code. You can also manually search for a code by pressing 9-9-1 after holding and releasing Set. Then alternate between pressing Power and TV (for a TV code). Lock in the code when the TV turns off by pressing Set. Check if the remote works for other features.
You can get the manual and codes for the One For All remotes here: http://www.oneforall.com/support/manual .
If your remote is older than your TV, you may need a new remote. Universal remotes are usually limited to codes for devices released 6 months or more before the remote was programmed.
I hope this helps.
Mar 15, 2011 | One For All URC4220 Remote Control
Toshiba CT-877 Remote
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
Jan 06, 2009 | Toshiba CT-90157 Remote Control
Need code to program toshiba tv with Direct tv remote
Dec 06, 2008 | Directv RC23 Remote Control
Programming remote to toshiba Tv
Depending on the universal remote you can usually program the remote without knowing the codes. One way is to turn on the television, then follow the basic programming instructions for the remote, but instead of entering a code, hit the power button over and over again until the television turns off.
I hope this helps.
Ken
May 27, 2008 | Toshiba 27A34 27" TV
Toshiba 65H81 Step By Step
Could I get a copy of that manual please? Sometimes my remote works / and sometimes it doesn't. I use other remotes which are programmed for the TV, but it's the receiver eye on the TV which is intermittent. Does anyone know of a fix??
Mar 25, 2008 | Toshiba 65H81 65" Rear Projection...
One For All URC-3021 Remote Control Logo
119 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
