FixYa.com
Tags:
ASUS Pentium M Processor Board
My Asus Pentium M laptop refuse to power
posted by stephenb on Apr 14, 2007
My Asus laptop was soak with water incidentally overnight while shutdown.
On discovering that, I placed it in the sun for some hours to get dried. I tried powering it but only the cooling fan works and nothing else.
Please I need help to fix it.
I wouldn't mind paying for any assistance.
Thank you.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 14, 2007
Thanks for Trying (70)
tomj23
Rank:Guru Guru
Rating: 86%, 1470 votes
Not trying to flame Benimur but I would seriously reconsider the carbon tetrachloride route. This is a fairly dangerous chemical and exposure to it or its vapor can affect the central nervous system. Prolonged exposure can cause liver or kidney damage or cancer; chronic exposure can cause comas and death. Not really the chemical you want to be splashing around the house around kids?.
Remove all power to the computer including the CMOS backup batter, open it up remove as many parts (hard drive, keyboard, PCMCIA cards, etc.) as you can and let it dry out upside down for several days in a dry hot room. It would be better to disassemble and air dry, but if you can?t go that route the other way should work, eventually. Definitely attempt to recover you valuable data by connecting the laptop drive to a desktop as a slave but again be careful. There is always a chance that the laptop drive could be damaged and could in turn damage the desktop.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Benimur
Rank:Guru Guru
Rating: 86%, 1989 votes
Hi, pls, soaked as in submerged or drenched like under the rain? If the laptop was submerged, then you not only have problem with the motherboard and hard drive but likewise with the lcd panel; the most I can suggest is to try and recover your files from the hard drive if they are important. If just drench, then you have to disassemble and clean the inside circuitry using a chemical compound for that purpose such as carbon tetrachloride. Be careful since it's strong enough to damaged some plastic. Pay special attention to the push in connectors and the pins of the components such as the ics. Hope this works out for you. Good luck and regards.
Comment by Benimur, posted on Apr 14, 2007
Hi all, thanks for the caution tomj23, in any case any electronic contact cleaner should do the job and most are available in aerosol can in most electronics repairs/parts shop. cheers.
Can you Help with these Processors problems?
Processors
i d number
miss placed product i d number... Answer This...
Processors
email
I'm really disappointed in the... Answer This...
Processors
Window Vista business - window...
i had Laptop Toshiba model... Answer This...
Processors
driver
mass storage controller Answer This...
Processors
1997 packard computer gave to...
packard bell computer (pc)... Answer This...
Repair Service
Find Processor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
