Question about Sanyo Vizon LCD-15A2 Television
Weird message on the tv
I hit something on the remote to the tv and now I have a message that says First please connect cable system or the antenna to the terminal on the back.
then press the channel up key
  • 1 more comment
  • Anonymous Jan 09, 2009
    Sanyo Vizon Model HT-32744 says no signal scources after
    doing Digital scan which I don't want to do.Has cable,VCR.
    DVD plugged in.Worked fine till today.
  • joelphilo Jan 22, 2009
    I got the same message today after the kids rolled over the remote. I've reconnected everything but it just keeps scanning without ever finding any channels. Cable works on the other TVs.
  • gburt Feb 19, 2009
    I hit something on my remote and now have a message saying First
    connect all signals and antennas to jacks and terminals on the back of the tv. Then presss the channel up key. HELP!! ggb
Just letting the TV run for about ten minutes while it "thinks" seems to be the best answer. The more I tried to do, the longer it took. But just letting it stay on and sit for a bit it eventually switched over to static, and from the static I was able to get back to the channell with cable.
Posted on Jan 23, 2009
    Problem Solver:
  • 6 Answers
It seems attenna signal strength not enough.Please check the antenna.if possible clean and reconnect jacks
Posted on Dec 24, 2008
We have an antenna, digital converter box, and digital tv. Can only get 5 channels. No nbc, abc, cbs. Get the message indicator available for digital broadcasting only
You should be able to use the box remote and select channel search mode. As it searches, you will see it "hit" available channels and store them. When channel search is finished, you should see a picture displayed. if no results, there is something wrong with the antenna, the way it is connected to the box, the way the box is connected to the TV, or the way the TV is connected to the box. You may have to reread the instructions to find what is at fault.
Sep 05, 2015 | Televison & Video
I turned dish on and all I get is snow
Check the input cable to dish box for firmness and the orientation of the dish.
Feb 16, 2015 | DISH Network Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
Jan 22, 2011 | Sanyo DS31520 31" TV
I'm trying to change the tv from cable to antenna tv from menu. Is there something that i don't understand because i can't get it to switch over.
go to menu then set up and select antenna and either hit enter or exit menu and that should do it. That is how I set mine up on my Vizio setting it up from antenna to cable.
I sure do hope that helps cause tv remotes can cause a real headache sometimes.. If it don't work let me know and I will try to look up a manual for the programming for your TV and Remote if you provide me a model number and stuff that would be required..
Stormi
Nov 15, 2010 | Symphonic Televison & Video
Have Lifestyle Bose 48 installed by Bose technican. All has been well. I was attempting to watch a movie on Demand from the Cable and it was doing tracking blurring... Must have hit the wrong button on the...
Does the Bose unit have selections for more than one signal source (video 1, video2, antenna 1, antenna 2, dvd, etc.)? If so, test to be sure that it is set to the correct input. Also, if the television has these options check it as well. Good luck and let me know how you make out.
Jul 05, 2009 | Bose Lifestyle 48 System
Blank TV screen
Was an auxillary input accidently selected? Try selecting inputs to see if this straightens it out. What model set do you have?
Feb 03, 2008 | RCA R52WM24 52" HDTV Projection Television
I need help now
Have you tried turning your cable box off, given it 3 minutes then turn it back on. We have Time Warner Cable and their remote has the tv and cable buttons at the top right of it and sometimes that helps. Good luck
Jun 08, 2007 | Sanyo AVM-3659S 36" TV
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Televison & Video Logo
601 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
