Question about Whirlpool GS6NBEXRQ Side by Side Refrigerator
Whirlpool Refrigirator I Have a side by side model FRS26ZPH 26.3 The freezer keeps acummulating water at the very bottom . I empty it out in about 3 days its full and running out the front till it freezes up . I think its the auto defrost but i dont know for sure.
    President:
  • 1,462 Answers
Water is probably caused by ice blocking the drain for the auto defrost. take off the back panel and you may see ice accumulating at the bottom of the evaporator. switch off, clear the excess ice with a hair-dryer used carefully and make sure water runs down the drain freely. ice in the drain may take some clearing - boiling water and patience are needed
Posted on Apr 15, 2007
SOURCE:
Hello i have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the freezer at the front left hand side.there is also a build of of frozen water at the bottom of the freezer.I have...
The most likely source of that water is a frozen/blocked drain for the defrost drain at the bottom of the freezer behind the back wall of the freezer.Its a fairly common problem so i have written this tip explaining how to clean that drain for the defrost.
http://www1.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Oct 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Freezer only working. Refrigirator bottom side water coming with rusrt
Your freezer is cooling but its not defrosting.The drain line hole is also blocked, so water is coming to bottom side of fridge. It's defrost problem.--------- Click this link below for troubleshooting and resolving the problem :---
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | GE GSH25JFT
Kenmore elite refrigirator water dispenser issues
If you can get at the refrigerator compressor, vacuum off the dust that has accumulated on it. This may help.
Aug 30, 2009 | Whirlpool ED2FHEXN Side by Side...
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool refrigirator with top freezer
run your hand around bottom door seal see if you can feel a warm spot, if you do check that area for contamanation ie;particals of food etc if not pull the seal in that area back slightly see if seal is split.if all seems ok look at the drain hole at the back of your fridge inside it often clogs up with small particals of food if this is the problem use a pipe cleaner to clean it.if its cloged water will be seen lying at the bottom of your fridge ;if any of the above do not cure your problem turn down your fridge a little this will not affect your freezer.hope this helps you.adrian
Jan 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My Maytag side by side freezer/refrigirator MODEL MSD 2554AR is having ice frozen at the botton of the freezer basket.This later melts and form water on the floor of my kitchen.
Ukoni, the drain tube for the defrost is frozen over or clogged. When the unit goes into defrost the water is running out through the front instead of down the drain tube. You can try to pour some real hot water with a baster to clear the tube. Remove the lower basket and at the bottom of the freezer panel in back is where the drain line is located. Catriver.
Jun 10, 2008 | Maytag Refrigerators
Whirlpool GS6NBEXRQ Side by Side Refrigerator Logo
112 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
