Question about Canon BJC-85 InkJet Printer
CANON BJC-85 Won't print black...
Had lost power cable for about six months before locating one online that I could afford for $19.95 + S&H so the printer sat dormant for a while. Upon receipt of the new cable today, it fits and works fine, providing power to the system and follows print commands; however, nothing is printed on the pages that are printed. I have input a new black ink cart and set to color printing test run, and all black text run. Neither will output anything. I ran the deep head cleaning tool 5 times to no avail. Nothing is printing although it performs as though it is printing -- nothing is printed on the pages output. I removed the new cart and rubbed the pad to see if maybe it was dried up or something. Ink is flowing properly from the cart so that's not the problem either. Error message states communication problem but it this were the case, it should not appear to be printing as I command it then output nothing. I have checked the cable and it is the correct Canon BJC-85 cable for this particular printer. This cable is a hard-to-find cable because it's a 13-V output device so I know that's not the problem either. It's getting power, it appears to be printing and working properly. It's just not outputting anything to the printed pages. What could the matter be? Thank you for your quick response. Sincerely, Iris Brand
  • Park wench Mar 20, 2008
    My Canon BJC-85 sat idle at least a couple years. I just powered it up and connected it to Win XP Pro via USB cable.
    I removed old BCI-11 Black & BCI-11 Color cartridges and along with the carrier which held them. Then I opened a sealed genuine Canon BC-10 Black ink cartridge with its carrier and installed it.
    Problem is that after a dozen-plus head cleanings and deep head cleanings I still get blank page when I attempt to print a nozzle test; still get a blank page when I tell it to print the Demo Page.
    Any ideas?
Turn on printer, press cartridge button, remove cartridge. On left side of remaining cradle, unsnap the cradle, lift up and remove. Take the cradle to your sink, wet a paper towel, and GENTLY wipe the long print head with the wet paper towel. Then run a small stream of clear cool water through the cradle, from the round pad that your cartridge rests on, until the pad looks ink-free. Dry everything with tissues and a hair dryer set on low, replace cradle in printer, replace cartridge, turn on printer, press Resume until it beeps three times, which runs the deep cleaning program, and after the procedure is finished, your printer will print as new.
Posted on Jul 29, 2012
It sounds like you only replaced the printer cartridge, not the print head. However, since it sat for an extended period the print head may need replacement. If you know of someone else that has a BJC-85 try their print head and see if that resolves the issue. You can buy both the head and cartridge together, but the cost about $45. Cartridges only come typically three to a package and are about $20.
Posted on Mar 03, 2008
BJC-85 canon printer.....brand new cartridges both b&w and color. Error light chimes 8 times and won't print
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printer starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beep
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Aug 07, 2010 | Canon BJC-85 InkJet Printer
My Canon BJC 85 printer needs a new black print head but they do not seem to be available. Any thoughts on a fix?
You pretty much have to buy another prnter. I've had same troubles. Go on ebay to search for print heads for the BJC-85. But for the cost--if you can find one, since this is a much older printer--it's more cost effective to just get another printer. The problem is, that when the print head goes out again, you end up getting another and another printer, so that you've got several printers that work fine, but only one print head.
I have trouble that when the ink stops printing, I've cleaned the heads with alcohol, and then it just seems to shut down. I cannot get anything to print thru a head after cleaning with alcohol, even tho' other sites suggest it. Had same trouble with Canon i70 and i80 printers, too.
If you haven't purchased on ebay, take your time, because sometimes prices for another used printer can be good, sometimes super expensive. You can find a bargain, if you don't need to get one with power cord, because you've already got one. Good luck. Terry tlworkroom@lycos.com
Apr 20, 2010 | Canon BJC 85 InkJet Printer
Error and power light blinking.
Here is the Waste Tank Full reset.
Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
4: Release buttons after the printers starts up
6: Press POWER
7: Release all buttons after the beeps
9: Press RESUME
Mar 30, 2009 | Canon BJC-85 InkJet Printer
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
PRINTER BEEPS (5) TIMES, ERRORS
Nov 29, 2007 | Canon BJC-85 InkJet Printer
Problem!!!!
Try to replace the print head. I had the same problem. Changing the printhead resolved the problem.
Nov 19, 2007 | Canon BJC 85 InkJet Printer
Canon BJC-85 InkJet Printer Logo
660 people viewed this question
Clive
Clive
old marine
old marine
