Question about Uniden CLX485 Cordless Phone
Power went off last night and our phone stopped working
The base unit's Flash/Speaker button keeps on flashing every 2 seconds. Nothing on the display. Actually the display panel on the base shows "Uniden" which also keeps on flashing every 2 seconds. None of the buttons work. Tried putting in battery in the base compartment, but the same result. If I keep the handphone in base cradle, the handset buttons lit up; however the "charging" LED doesn't blink. Something got short? Is ther e any easy fix?
  • 2 more comments
  • Anonymous Mar 16, 2014
    phone base charging light keeps flashing
    Led on phone base keeps flashing
    phone base charge light keeps flashing
  • Anonymous Mar 18, 2014
    Flashing 88 on base
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Posted on Jun 19, 2008
Have 2 units both just flash "loading" and will
This happened last night on my new-to-me JVC SR-MV55. Even powering it off for five minutes didn't help. It apparently crashed during dubbing (couldn't create more than 9 chapter codes?). Manual suggested holding down Stop and Power after powering it down. But no matter how long I held Power it wouldn't stop flashing. But I tried Stop/Powwer for a bit, nothing seemed to happen, then maybe 15 seconds later it restarted "WAKE UP'".
Mar 25, 2011 | JVC SR-MV55 DVD Recorder / VCR Combo
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Red Light Indicator Flashing??
There is an old message stuck in memory. Hold down the OFF button on the base handset for 10 seconds.
Dec 02, 2009 | Uniden DECT 6.0 Cordless Phone ID
Panasonic phone KX-TG4500 base not turning on, I have had it for 3 years and all of a sudden it died, like a battery goes off.
I could tell the base unit was about to go a few days ago. Have had the phone for years with intermittent problems but it has been for quite awhile now. However, the screen on the unit started to blink a bit a few days ago. Had a feeling it was about to go but the phone kept working until this morning when it suddenly dies. After reading that changeing the cord might work, I replace the unit power cord with one from my handset and the phone is working again! Thanks for the suggestion!
Oct 01, 2009 | Panasonic KX-TG4500 Phone
Phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
Apr 29, 2009 | Uniden Cordless Phone
Power button flashes SAFE
I unplugged the unit for 30 minutes and it finally went out of safe mode.
Oct 12, 2008 | Televison & Video
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Power button Flashes
    Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
    Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
    Uniden CLX485 Cordless Phone Logo
    824 people viewed this question
    Top Uniden Lands Phones Experts
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
