Question about Onkyo TX-8211 Receiver
Onkyo TX-8211 receiver with very low volume through speakers
I have not used this received for a while, but when I turned it on today I had to crank up the volume to max just to hear a muffled sound from the speakers. I tried it with a different set of speaker on both the A and B channel, same problem. I also plugged another receiver to the speakers and it worked fine. So, I'm sure it is not the speakers. Any thoughts on what might need to be fixed?
Thanks,
Steve
It's the Tape 2 button - unclick it.
Posted on Jul 09, 2009
Onkyo tx 8211 receiver shut off problems
Check all of your speaker wires and speaker turminals. I bet there is a short.
Apr 26, 2012 | Onkyo TX-8211 Receiver
TX-8211 FM Stereo/AM Receiver All has been fine
make sure that somehow the wires didn't get loose from the speakers in the back. Protect means that it's overloaded. Did you change the plus wires with minus wires maybe. Check to make sure all the wires are good.
Mar 19, 2011 | Onkyo TX-8211 Receiver
I have a TX-8211 but I am out of town looking at Internet Radio tuners. Can you tell me what type of inputs are on the Onkyo? I know it has the black/red spring loaded wire inputs but are there other...
Your tuner will be the limiting factor regarding sound. The Onkyo accepts any stereo analog input via RCA connectors, period.
Those "black/red spring loaded wire inputs" are speaker outputs and if you hook one of those to an innocent audio device's Line In connections you might kiss it all goodbye.
Read the manual...
http://www.retrevo.com/support/Onkyo-TX-8211-Receivers-manual/id/365ci165/t/2/
Feb 01, 2011 | Onkyo TX-8211 Receiver
My onkyo tx-ds838 motor fan do not move
The fan in those Audio System only turns at about 1/4 to 1/3 of the ride of your volume control.
It had been intentionnaly designed like that, to achive a quiet operation at low hearing volume.
But if the fan don't move by cranking up the volume at 1/2 to 5/8 of the volume control (with speakers on). You need to have the fan or the fan power circuit checked by technician.
Spider Guy
Mar 15, 2010 | Onkyo TX-DS838 Receiver
Onkyo TX 8211 protection mode is activated and i want to know how to deactivate it????
Eliminate the short or overheating problem it thinks exists. Disconnect all speakers first to see if one of them is the culprit. If it's internal, take it to a shop.
Jan 19, 2010 | Onkyo TX-8211 Receiver
VERY LOW VOLUME FROM SORROUND SPEEKERs
some surround sounds do not put out loud sounds except from the front speakers only. Try using different inputs to see if it makes a difference.
Jun 17, 2009 | Onkyo TX-SR605 Receiver
Sound cutting out
sounds like the tape monitor may be turned on. First place to check anyways. If it is not the problem, I am happy to talk more about it with you and do some more diagnoses.
regards
Graeme
Feb 14, 2008 | Onkyo TX-8211 Receiver
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Apr 07, 2007 | Onkyo TX-8211 Receiver
Onkyo TX-8211 Receiver Logo
1,322 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
