Question about Pentax Optio T20 Digital Camera
Lens opens, makes strange noise, closes
When you turn on the camera the lens opens makes the startup sound then it makes a strange noise and then it makes two beeps and the lens closes
i can view pictures when its plugged into my computer  but i cant make it go into picture mode or video modeI purchased two Pentax Optio T20 cameras from Costco less than two years ago. They both now fail to complete starting. It seems ironic that they both failed with the same start-up problems at the same time?? They both start, the lens opens, then closes with two beeps-what could cause this - and both failed together !! I sent one back to Pentax and they told me it would be $149 to fix each camera by replacing circuit boards. I think they just sent me a form letter. I don't think they opened the camera and checked out the specific problem.
Tnx Bob
  • robert4770 Jan 04, 2009
    I have 2 Optio T20 digital cameras purchased at the same time about 1 1/2 years ago. Both of them failed at the same time about several weeks ago. The batteries are charged and good. When they start, the green light comes on, the lens activates out, then immediately beeps sound and the lens closes and the cdamera goes off. How ironic that two cameras would have the same symtoms at the same time !! Can it be in the programing or what else ?
    Bob
  • 10,594 Answers
It is lens mechanism problem and mostly loading gears in lens worn out / exhausted. Complete lens assembly replacement is only solution but cost would be high.
Below is image of lens mechanism showing how is loading gear just for reference...
Posted on Jan 04, 2009
  • Pentax Master
  • 19,396 Answers
First buy new alkaline batteries and test them, if you put defective batteries on both cameras , that is a possible reason.
Regarding the firmware, there is no known time bomb case, and normally cameras without updates do not have this problem. I am sure that factory customer support will tell you the same. I would rule out this option.
The more likely is a short or a fault inside the camera , when the camera starts up, detects the problem and shut down. this problems are often originated on circuit board, or because of a short to chassy, faulty switch shorting etc.
Also still possible a lens error , but in that case you usually get error message.
A last possibility is that cameras had been exposed to same conditions , and this had damaged both of them.
For example if both camera had been exposed to wet weather, they may have developed oxide formation roughly at the same time, this caused the short and fried both camera.
In any case this is an hardware fault, and the cameras must be taken apart to fix them, even if you do not have to replace the main board.
Find a local repairman and ask a quote for the repair.
    Genius:
  • 1,239 Answers
Hi
Check the CF connector in the camera. One of the pins might be bent..
Posted on Jan 01, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, lets try the basic, battery. Not only ensure fresh, fully charge batteries but clean/scrape the battery contacts. Corrosion may have developed and thus can cause low battery input to the camera circuitry. In some instances, it may even be necessary to bend/stretch these contact pins/points to provide more pressure to the batteries themselves.
I am also inclined to suspect sand, dirt or dust has entered the lens mechanism and partially block lens movement at some point. Being an intricate mechanical problem, the correct procedure would be to seek the services of qualified professionals. However, a possible workaround would be to jar the camera lens into full action by thumping the camera base against the pal of one's hand or even an open book. This of course is not a sound technical solution and may even worsen the condition.
Good luck and Thank you for using FixYa. Happy New Year.
    Problem Solver:
  • 59 Answers
Change the battery get a new replacement one from ebay as it is very cheap hte same thing happened to me with a diffrent camera i bught a replaecement from ebay now it work perfictly i hope this helps.
  • 82 Answers
Hi .ok you seid you by those 2years ago your waranty is finish if you paid cash , but a thing i know when a do purchase whit my credit card i got a second years waranty thath meen 2 me be its your second chance . let me know yvon chow !!!
    Sergeant:
    Novelist:
  • 327 Answers
Either the lens is misallighned or its gor dirty and needs cleaning or its got cracked internally.or the assembly which moves the camera is bit loosened and needs reparing.
Posted on Dec 24, 2008
  • 15,935 Answers
Have you tried the memory cards in other cameras or PCs? sounds as if your cards are corrupt and need re-formatting.
Hi, my daughter was holding the camera (BenQ DC C1030 Eco) and it fell from her hands and it ending on the lens while it was still out, now it won't close and when i try to turn it on, it makes a strange...
It's not worth it. After a camera is dropped, it will develop other problems which are currently unnoticeable - just like an automobile after a major collision.
Dec 06, 2010 | BenQ DC C1030 Eco Digital Camera
It is making a constant strange noise when it is turned on. does it mean it is broken?
Not necessarily.
This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off:
1: Go into the menu
2: Chose option Cam Settings
3: Switch AUTO focus to single lens and click OK.
Jan 26, 2010 | Kodak EASYSHARE M763 Digital Camera
FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Jul 02, 2009 | Olympus FE-280 Digital Camera
Pentax Optio A10 Camera Lens won't retract
It sounds like you may have a bad lens assembly. If it is sticking open or closed, it will usually make a buzzing noise. If it fails to open or close all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Mar 27, 2009 | Pentax Optio A30 Digital Camera
Coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 26, 2008 | Nikon Coolpix L11 Digital Camera
Canon powershot s410 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Aug 20, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Buzzing sound
the problem is with lens.this sometimes happens if cam becomes victim with water.
there is some buzzing noise when the shutter of lens gets opened or closed.
please clean the lens with the solution once.then you can make out of blurs.
Apr 04, 2008 | Samsung Digimax S630 Digital Camera
Cannot open lens and take photos
sir, this is internal lens barrel,or gears problum,this is repairable
Feb 07, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Pentax Optio T20 Digital Camera Logo
55 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
