Question about GE Profile JT952 Electric Double Oven
Fuse location put in new bake element blew fuse.timer clock not working. where are fuses located on walloven model# jcks05gp-1,ge brand name
  • 700 Answers
Are you talking about the breakers that are outside or in the garage? Look where the main power goes into the building and there is where the breaker for the oven should be.
Posted on Dec 24, 2008
Oven elements not working
you must have a hi limit thermosta (fuse) out
Aug 14, 2012 | Frigidaire Ovens
Think i blown a fuse/ where do i find the fuse
First check to see if power is coming from outlet, with meter or check breaker in panel box of main. Then you will need to be careful and check inside of oven power supply inside unit
Dec 22, 2007 | Whirlpool RBS305PDS Electric Single Oven
Oven doesn't work (bake nor broiler) checked both heating elements there fine whats next?
With out a model number I was unable to look up any specific information.
First I would look for a thermo fuse on the back side. If you model has one it may be bad. If it's a older oven with a mechanical clock make sure the clock is not set to timed bake.
Aug 03, 2011 | Ovens
I just replaced my baking element in my oven, and when i turned the breaker back on, now the new element automatically heats up by itself and stays on....with everything off. The only way I can get it to...
If the only wires you disconnected and reconnected were the 2 on the element itself, the bake relay is fused. Depending on the brand and model, the bake relay can be located on either a realy board or the electronic oven controller. Either the controller or the relay board (if present), will also need to be replaced.
Apr 16, 2011 | Stoves Ovens
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
Replaced a burnt bake element in my stove and there is no electricity being sent to the bake element. All other functions (broil, burners) are working problem.
Can you provide a Make and Model please?
Many bake element power wires have an inline fuse wrapped in tape. If you can locate a bulge in the wire between the element and the control it is probably an inline fuse. You wil have to probably cut open the wrapping to gain access to the fuse. This may not be the solution for your unit but take a look for the bulge.
Kelly
Feb 09, 2010 | Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven elements will not heat
theres a thermostat on the back wall that problaby blew out as a result of surge,its wired in line with both bake andbroil element
Feb 24, 2008 | Whirlpool GBS277PDS Electric Single Oven
GE Profile JT952 Electric Double Oven Logo
207 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
