Question about Akai LCT2715 27 in. LCD Television
Power supply rebuild
Are you still fixing the power supplies for this tv. The light is flashing orange and there is a ticking noise coming from the power supply board. I have the board out. Please confirm the price and shipping address. My email is robmooredesigns@bellsouth.net
  • 2,336 Answers
You can write to jah2mil@hotmail.com for more info on repairing cost and where to send the power supply for repair.
Posted on Dec 27, 2008
It started to just click for several minutes when you try to turn it on before it would finally come on....Then it started to make that same clicking noise in the middle of the night even when no one was...
Tv power supply board it is causes and the problems.That the board where the tv power a/c cord plug into it.Take the tv aparts,check the tv power supply board carefully for dying and leaking capacitors components parts.These dying and leaking capacitors components parts are alway bulges ups or puffing ups onto it tops.U have all the tools and know basic electronic?Yes,than u must changes all these dying and leakages capacitors components parts are bulges ups or puffing ups onto it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.As soon as the tv have a stable power supply board is it alway supply correctly voltages and current to the tv.These clicking noises will stops as tv turn on or the tv putting on standy power.
Aug 20, 2011 | Philips 50PFP5332D 50 in. Plasma...
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Screen suddenly turned off, makes an odd high pitched noise when it tries to turn back on. power button flashes orange
Sounds like there is a power problem if the neutral (return) wire on the power supply has become high impedance (or even disconnected) then you will get a high pitched sound coming from the TV PSU also the voltage that is presented will not be 240V which will give you the same problem.
The orange power button means standby if you fix the PSU then the TV might work again but it may have been damaged by the PSU.
Jan 07, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
Akai LCT2716 Flat Panel TV
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Mar 12, 2008 | Akai LCT2715 27 in. LCD Television
Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
My LCD power light flashes orange and screen is blank and there is afaint ticking noise coming from the monitor. Can anyone help?
Due to still having a power light you can bet the power supply is still fine.
The problem will be in the inverter circuit, but more to the point it's actualy one of the CCFL tubes that has blown.
They can be easy to replace, they can also be a complete nightmare.
Hope that helps =)
Sep 21, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Akai LCT2715 27 in. LCD Television Logo
144 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
