Posted on May 28, 2017
My rumor touch just shut off on me the other day I thought it was dead but I tried charging it and it still won't turn off this happenined while I was listening to music but I don't know if that has anything to do with it also everynow and then it will turn on hit only the home back and call button turn on and the red led turns on but it won't do anything almost as if it can't turn on all the way.. Any solution I didn't do anything to didn't drop it it just shut off
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jul 06, 2008
SOURCE: HELP!!!!! My zune's buttons are not working!!!!!
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Anonymous
  • 11 Answers
  • Posted on Feb 14, 2009
SOURCE: shut off on own now wont turn on or charge
Battery is dead.... Let it sit connected to the pc it will come back on.
Anonymous
  • Posted on Mar 12, 2009
how can i download microsoft frontpage????
Anonymous
  • Posted on Apr 27, 2009
SOURCE: ipod will not turn on..
i just braught my mp3 and it worked for a little bite now it will not turn on
Anonymous
  • 40 Answers
  • Posted on Apr 16, 2010
SOURCE: my Zune HD won`t turn on, what do i do ? =]
Hold the power button for 10 seconds. this should cause reset. if it does not hold it again for 15 seconds this should cause it to power into repair mode where you will then need to plug it into your computer and update the firmware with the included software. hope this helps!
Kindle Touch won't start
Bad battery, needs changed.
CS55 headset battery was dead (app 1 1/2 years of service). I replaced it and fully charged. Worked fine for 3 or 4 days. Now, won't charge. Tried the system reset and power cycle, no...
On your base there are the numbers 1-4. Put the # 1 in the 3 O'Clock position like a clock. Try putting the letters that are in the bottom on B.
Good luck from Headsets Direct - 800-914-7996.
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
I droped my lg virgin rumor touch and The touch screen cracked but when I turn it on it stays black. What could I do?
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
LG enV touch keeps shutting off when charging
I would replace the battery and see if that helps with this problem
 Grubhead
Grubhead
SmartAviator
SmartAviator
