Question about U-Line Icemaker
Frigidaire FRS23HF5A side-by-side gets water to door, but no ice.
My wife just ran two bags of ice on Saturday (large ziplock bags) for an open house on Sunday afternoon. She emptied the icemaker.
Now, we can't get any ice from the icemaker. The metal sensor rod is in the "on" position.
I've checked the water supply and the water works to the door. I've also pulled the filter catridge, and it is not clogged or damaged.
HELP??? This Frigidaire is located in a church parsonage and I'm trying to save the church from an expensive service call.
Thanks
Dr. J. Dean McNamara
Pastor
First Baptist Church, Sedan KS
  • 1073 Answers
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Posted on Jun 24, 2008
  • 27 Answers
SOURCE: Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
  • 286 Answers
SOURCE: U-Line co29ff, brand new unit. Makes clear, hollow, watery ice.
2 things you need to check. If you remove the icebucket look for armaflex the goes on the sensor tube from the icemaker to the back wall. If missing call U-line to get the correct one. The second thing you can do is check the icemaker control. Remove the grill, on the base in the right corner you will see a control with a screw. Turn the screw all the way to the right then back it so it will be straight up and down.That will set it cooler
Posted on May 14, 2009
  • 286 Answers
SOURCE: U-Line Model WCM48
You can try to advance your icemaker by removing the white cover on your icemaker and turn the smaller gear counterclockwise to advance the icemaker. When the icemaker starts wait until the ejector blade gets to 10 oclock position this is where it calls for water. The test would be unplug the coil on the valve and put a meter lead on each one. If you see 120 volts then replace the valve. If you dont see it it could be the water switch inside the head of icemaker.
Posted on May 18, 2009
  • 286 Answers
SOURCE: I have a U Line
You can try to advance the icemaker and when the ejector blade gets to 10 oclock it should call for water. If the coil on the watervalve is working you should hear vibrating. If not then it could be the water switch in the head of the icemaker. Or you can ohm out the valve(coil) to see if its open.Try that first it could still be that the thermostat isnt being satisfied.
Posted on Aug 11, 2009
My Frigidaire has a bad odor in the freezer and the air blowing into the fridge...the ice tastes bad as well but the water is okay? Help
Sounds like you need the water lines and the ice maker housing cleaned as much as possible. Contact a professional for the best way to do this.
Dec 28, 2012 | Frigidaire FRS26R4A Side by Side...
Tip
Unthawing the water dispenser in the freezer door
If the icemaker is loaded with ice or certain areas of the freezer are perhaps overloaded redirecting cold air toward the water output it can freeze. Also if the ICE shoot has ice cubes obscuring it's closure that area gets cold enough to freeze the water. Check after dispensing ice that the round flap is closed.
I open the freezer door and place three regular sized bed pillows placed into white trash bags into the opening being sure to DEPRESS the light latch with one of the pillow placements so it won't constantly sound a door ajar warning.
I then close the door as much as the pillows will allow and place a chair in front to keep the pillows in place for about 25 minutes. Usually this will do it and the water will begin to flow . I draw off enough to run it completely through the entire line . Sometimes a small piece of ice will come out. I had tried hair dryers and all manner of things and just gave this a shot one day and it works when it freezes for whatever reason it will use.
on Apr 26, 2015 | Frigidaire Gallery GHSC39ETJB 22.6 Cu. Ft....
Tip
How to save a wet cell phone
if your cell phone gets wet immediately get a bag of rice and pour it into a ziplock bag or any large sack or container. put your cell phone in and cover the phone with the rice. it is best to use a ziplock bag so that you can shake it up. make sure that the battery is out of the phone and that the back is left off of it. how this works is, the rice gets into the phone and absorbs the water, so that it will not cause the phone to become waterlogged.
on Dec 02, 2009 | Cell Phones
Water not getting to icee maker byt door water works
you have to solnoids one for water and one for ice maker it must open up for water to get into ice maker. but is the ice maker arm down so it can call for water?. check that ok.
Feb 12, 2011 | Frigidaire FRS3R5EMB Side by Side...
Keep getting download message
You may still have water in tight places due to water surface tension. Open all the access doors, take out the SIM card, battery and anything else that is removable and put all parts in a ziplock bag. Get some dessicant bags (from old shoe boxes), cardboard pieces, saltine crackers and put them in the ziplock bag also and put on top of your microwave oven (if it is used a lot) or in the window where it gets direct sunlight. Leave it there until moisture gets on the bag then disappears again (3-5days) The dry items in the ziplock will help draw out all the moisture better than air drying. I have done this many times on cell phones, gameboys, etc. and it works everytime.
May 16, 2009 | Samsung Propel A767 Cell Phone
Dropped in water
You may still have water in places not reached by the hair dryer. Open all the access doors, take out the SIM card, battery and put all parts in a ziplock bag. Get some dessicant bags (from old shoe boxes), cardboard pieces, saltine crackers and put them in the ziplock bag also and put on top of your microwave oven or in the window where it gets direct sunlight. These items will help draw out all the moisture better than the hair dryer. I have done this many times on cell phones, gameboys, etc. and it works everytime.
Apr 25, 2009 | Samsung SGH-G600 Cellular Phone
Please help
Open all the access doors and covers, take out the game, and put all parts in a ziplock bag. Get some dessicant bags (from old shoe boxes), cardboard pieces, or saltine crackers and put them in the ziplock bag also and put on top of your microwave oven or in the window where it gets direct sunlight. These items will help draw out all the moisture. I have done this many times on cell phones, gameboys, etc. and it works everytime.
Feb 28, 2009 | Nintendo DS Console
Frigidaire FRS23HF5A side by side
Check your ground from the door to the box at the top of the door. Run a small length of wire from the bolt of the main box to the door bold at the hinge on the top. This will ensure grounding of the door.
Other possibility is the ribbon cable from the dispensor to the power board. connection may be loose.
Jul 02, 2008 | Refrigerators
U-Line Icemaker Logo
85 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
