Question about Whirlpool Duet GHW9150P Front Load Washer
Controle light stays on
I can not get the control lock off so I can do my laundry can some one help me? I have unpluged the machine, I have turned off the machine and tried to restart it again but it will not let me restart machine with another load. not sure how it got into the control lock mode. And i have tryed pressing the butten that sys Controle lock hold for 3 seconds to lock/ unlock controle lock
  • tbone357 Apr 10, 2008
    This fixed my problem. Thanks for the help. I wonder what makes it do that or maybe someone was pushing buttons.
    President:
  • 1,294 Answers
Press and hold 'dry' & 'spin', shd unlock
Posted on Apr 14, 2007
  • 1 more comment
  • prem mathew Apr 16, 2007
    Try holding in the "End of Cycle" tone button
  • prem mathew Apr 18, 2007
    Bottom right hand corner, end of cycle button, hold it for 5-6 seconds; machine will fix itself. This is the 'child lock device'.
    It turns the control lock on, do it again, and it turns the control lock off, on both the washer and the dryer.
    Pl post back results.
  • randysplace Jan 21, 2011
    I had misplaced my manual for the duet washer and the control lock was on - I followed your instruction and held the end of cycle button in for 5-6 seconds and wah lah the light went out and I now have control over my washing machine again. Thanks so much for posting this!!!!
Super Genius! No manual to speak of as it was a scratch and dent sale. I was just about to get a sledge hammer or call a repair man. Saved my masculinity, I appreciate it greatly
Posted on Mar 26, 2008
BRILLIANT!!!!! Why isnt that in the Troubleshooting part of the Manual?
Posted on Dec 17, 2007
Thanks for the FIX!!!
Made me feel real stupid after reading " hold for 3 seconds to unlock child safety switch"
DOH
Posted on Dec 09, 2007
This was my problem also and i tried solutionregarding end of cycle and like magic i no longer have my manual so thanks saved me time and hairs lol
Posted on Aug 25, 2007
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control lock is on & will not turn off....Ican not wash laundry.
4lulia,
If your wash is DONE... Unplug the machine... the lock should release.
If the lock keeps doing this... you may need to change lock
Are you in the GTA area?
Send me an email
bweazer at yahoo dot com
Let me know if ok
Oct 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control panel
select and hold END OF CYCLE SIGNAL for 3 seconds untill the CONTROL LOCKED status
light turns off. The button you need to hold down is under the louder, softer, and off volume
control buttons.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Locked
find button with lock emblem underneath hold in for 3-5 sec should release control panel lock may be no good reason but they have been known to lock because they want too remember your dealing with a computer any random signal may cause this if all elese unplug for 20-30 min and retry
May 19, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool duet
On the far right sode of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear.
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Re: control lock is on
FOUND OUT HOW TO FIX PROBLEM . ON MY WASHER AT BOTTOM RIGHT HAND CORNER ,IT SAYS END OF CYLCLE SIGNAL. HOLD IN FOR 5 SECONDS AND IT WILL FIX ITSELF
Jan 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
125 people viewed this question
Sal De
Marvin
Marvin
jimorris77
