Question about Dell W3706MC 37 in. LCD HDTV
Connecting external speakers with optical cable
I have the optical cable plugged in to the tv and the other end to my surround sound and i'm not geeting anything. do i need to turn my built in speakers off somehow?
  • 69 Answers
Id say you DO NEED to adjust your TVs audio settings.
Posted on May 10, 2009
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
Tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
on Aug 13, 2010 | Audio Players & Recorders
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
How to connect my bose solo to my 2009 samsung tv
sounds like you have it set correctly..do you have any other sources than external,(such as audio out) ?If so that should solve your problem...does the system have any other connection outs, such as red white audio cables (LR audio )? You can use them as external when the optical is unplugged...if you get sound you either have a bad optical cord or the output for it is defective..good luck GOD BLESS
Oct 12, 2017 | Samsung LN46D630 46 inch LCD 630 Series TV
How do i hookup my magnavox mrd 210 to my lcd tv for surround sound. have tried to connect with rca wires in back of tv to surround sound system and nothing. tried side of tv and nothing. my surround sound...
Have you seen the user guide?
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036122.pdf
The TV is intended to be an end point of the video, not a source of audio. Many TV's (monitors) don't have ANY audio, much less surround sound capability. Composite Video is theminimalist video connection for setup; Component video to the TV should suffice for viewing DVD's.
Is your TV the SOURCE of surround sound programming (via an antenna) or does the programming come from elsewhere like a Cable Box? THAT would be the source you need to tap for surround sound.
Aug 23, 2011 | Philips Magnavox MRD210 System
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
I just bought a Panasonic TV model TC L37E3 and I do not know how to coneect my external speakers. Please help me as I feel very frustrated by now. Carlos
Carlos, I just bought an LCD tv too. To connect external speakers to mine I had to buy some high end 5 channel pc speakers and connect them through the headphone jack(I know how stupid that sounds considering we spend $1000.00 on a TV and thats my only option for external speakers.I looked at your owners manual and didn't see a headphone jack though so you may have to opt for speakers that plug in with through the usb port. Some new tvs won't support external speakers unless you use complete home theater surround sound system which will connect through the rca cables (red,white)
May 22, 2011 | Panasonic Televison & Video
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
NO OWNERS MANUAL
Go to there website to download the pdf version of the manual.
If that does not help look on the back and you should see optical out, audio out type connectors.
Most effective way would be to buy a surround sound amp and connect it via an optical out to the surround sound amp and the surround sound amp will have the connectors for the surround sound speakers.
May 18, 2009 | Proscan 42LA45H 42 in. LCD TV
Dell W3706MC 37 in. LCD HDTV Logo
367 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
