Please help tv wont turn onclick on the remote power button - hear a click a red button - labeled "stand by time in" flashes on the tv set - but the tv doesn't come on. Then after a couple of days you power the tv on - tv comes on clear as day no problem - plays for a couple of days and then the same thing happens again.
TV is a Sony WEGA
Unplug the tv from power outlet for a while then after 10 mins hold the power button to on the tv and keep it holding for few more secs to let it come out of standby mode.thn off it again n re ON it.it will work properly.
4 times blink in KV-32FS120 model shows problem in vertical deflection area.
As its bit old TV so I'm sure it has few cold / dry solder joints near vertical output chip and might require few weak capacitors replacement.
If you are not familiar with TV repair, please get help of TV Tech for proper and safe fix.
Very common problem for this is that the tiny electical components on the main board of the tv are getting heated up and making this problem or any of the such components are gone loose and needs resoldering .just check out on the main board with a multimeter to locate this faulty ones and replace them to make it proper.not at all a major fault in the tv will get easily repaired.
for required small parts you can get them at
radioshack websites
