Question about DXG Technology DXG-506V DV Digital Camcorder
DXG-506V Won't turn on with card.
I purchased camera used. Works fine with built in memory, but won't work when I insert 2gig SD card. Card is new and works fine in my digital camera.
any ideas? Thanks
  • klit Dec 29, 2008
    Had same prob with sdhc only card went to just sd card worked ok still going to see if I can use a compliant card check "tiger Direct" for different cards and prices.
    KIT
  • Anonymous Jan 24, 2009
    My camera is doing that too. I recently bought a 1 Gigabyte SD Card, and everytime I insert it, it shuts off automatically. When I go to restart it, it stays half way between on and off for five minutes, and then shuts off.
    It's ticking me off.
jbreth
  • 69 Answers
SOURCE: SOFTWARE
The camera you purchased usually comes with power director,win movie maker will also work. Here are a couple of links to sites that have them available: http://www.cyberlink.com/multi/products/main_4_ENU.html http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx
Posted on Aug 25, 2007
SOURCE: need help with my dxg 506v
How do I get a program so I can get mp3 music?
Posted on Dec 27, 2007
  • 3 Answers
SOURCE: Using DXG 506v as webcam
when you hook your camcorder in via USB cord, there will be 3 options, mass storage, DPS, and pc cam, choose the third and usualy chatting websites will automatically recognise the camera and your all set!
Posted on Apr 20, 2008
leecom72
  • 4806 Answers
SOURCE: I need the owner's/ instruction manual for a DXG-506v digital cam
get the manual here:
http://www.dxgusa.com/Support/Manuals/English/dxg506v_eng.pdf
kind regards and please rate us
Posted on Dec 09, 2008
hmerchant110
  • 7191 Answers
SOURCE: Where to I get drivers for my DXG Digital Video
You can download the required drivers from:
http://www.dxgusa.com/downloads
Hope this solves your problem. Thanks.
Posted on Nov 28, 2009
I have had my camera for 3 years but never had bought a memory card for it. I recently purchased one from Walmart. When i put the memory card in the digital display almost gets stuck and won't open so...
The camera takes SD cards up to 2GB (not SDHC cards). If you've been taking pictures using the camera's internal memory, you must first get rid of those pics. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert your new card and go through the "format" routine again to prepare the new card.
Sep 02, 2011 | Konaki DV7-Z Digital Camera
I need to salvage older jdc64 4.0 megapixel camera that does NOT recognise 2gig memory cards. a store had an old "type sd" memory card they use for diadnostics behind the counter that was rated...
Since this digital camera is an older model, it probably isn't compatible with 2GB memory cards. Older electronic devices including card readers, camcorders, MP3 players and even older laptops with built-in card readers won't be able to use higher-capacity cards. Try using a 1GB memory card in your camera and if it works, then 1GB is the maximum size of memory card you can use on that camera.
May 20, 2011 | Jazz JDC64 Digital Camera
SD card problem
here is a list of compatable memory cards
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=42425
.. any SD or MMC card should work up to 4 gb ... so your 2gb should be ok .. i suspect that it may be damaged .. you can try formatting it in a USB card reader if you have one on your computer .. some laptops have the SD slot built in .. there was some compatability issues with memory cards for older cameras but there shouldnt be any with such a new machine .. make sure the contacts are clean and the "protect" switch (if any) is in the unprotected mode .. when you format the card it may take several minutes so give it time .. if you are going to take movies then its better to use a "high speed" SD card .. like the 133x mentioned in the above URL .. slow memory may cause missed frames or 15 fps instead of 30 fps record rates.. .
the specs on your camera do show SD and MMC compatability .but they dont show any brand preference .. .
Oct 06, 2009 | Pentax Optio 33LF Digital Camera
My sdhc card wont work
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 19, 2009 | DXG Technology DXG-506V DV Digital...
My camera won't turn on!
Check your memory card you need a sd card or mmc for this camera make sure your card is not an sd hc card over 2gb it will not support it
Feb 14, 2009 | DXG Technology DXG-506V DV Digital...
Webcam? No CD...
I had same prob with sdhc card however another just sd card worked ok going to try sd compliant card listed on "tiger direct" to see if it will work. note they also have reasonably priced just sd cards listed also.
KIT
Dec 22, 2008 | DXG Technology DXG-506V DV Digital...
SD card rejection
I have seen SD cards go defective. Also, enquire to the manufacture of the camera or at least the dealer to make sure that the model of SD card that you have is compatible. I have seen compatiblity issues with particular SD card types on specific models.
Jerry G.
Jun 06, 2008 | DXG Technology DXG-518 Digital Camera
DXG 506V Will not turn on
I had the same problem ...I bought a new 2 GB SD card put it in the camera and it worked fine.
It may have had something to do with formatting ..I tried to format the other card wiyh my computer when the video camera would stay on.
I tried to reset the camera that didn't work either.
The new SD Card did work.
-Steve
Jun 04, 2008 | DXG Technology DXG-506V DV Digital...
DXG-506V LCD comes on Blank White Screen
-Steve
Jun 03, 2008 | DXG Technology DXG-506V DV Digital...
Insert memory card, LCD turns lank
Hello Rach326, try with a new SD card. If it does not help contact the nearest authorized dealer/service. Best regards, Arpad
Jan 12, 2007 | SeaLife Reefmaster DC310 Digital Camera
DXG Technology DXG-506V DV Digital Camcorder Logo
94 people viewed this question
Top DXG Technology Video Cameras Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jose Ma DM.
Jose Ma DM.
Tony Parsons
Tony Parsons
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
