Question about Lexmark Office Equipment & Supplies
Printer ran out of ink, replaced with new black and color cartridges, ran test patern does Ok colored,then tried to print from word perfect in black only, paper came through blank, then tried to run copy from an e-mail the colored part of e-mail came through fine but the black print did not print.
  • 10,594 Answers
Just unplug printer from ac outlet for couple of minutes and replug it. this will reset printer internal circuit and hope it will work good.
Posted on Dec 24, 2008
    Sergeant:
    Novelist:
  • 327 Answers
You need to adjust the colour and black settings while printing as some of the settings are turned off and needs to be on.check out in the printer properties and make them on.and then print a printer test page and check out if every thing comes properly before taking any other printouts.if nothing solves just uninstall the printer driver and reinstall it again all the required settings will be automatically selected not to worry. thanks.
  • 100 Answers
U must hve set it up to print in colour only.change it to default settings to overcome any change in settings.
  • mayiassistu Dec 24, 2008
    go to printer properties then to printing preferences and then to lexmark solution center.and check whether u hve selected both ur new cartridges to print or only colour.these settings needs to be made for both the cartridges when new cartridges are installed everytime.
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Sep 12, 2013 | HP Officejet 4500 All-in-One -...
Printer will not print in black and white only.
The printer will not print unless you change the specific cartridge that is empty, so change the cartridge and install a full new one. then you should be ok
Sep 03, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Color ink cartridges empty, printer wont continue to print
select print black only from the print or page set-up.
Mar 30, 2009 | HP Color LaserJet 2600n Printer
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Color printing
well there is always a way to reset the ink reading from the printer software or drivers thats the first thing i can think about
but did you try to remove the color cartridge and put it back in after turning off and on the printer
i mean take off the cartridge and turn of the printer
turn it on and put the cartridge back
see if that is going to help
and as i said check the printer driver and right click on it go to properties and check the color management bar.
i hope that would be
take care
Oct 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printing in color
Since you already tried cleaning tha colored cartridges the next thing that you can possible do is to remove all the cartridges then turn off the printer for 5 minutes then put the cartridges back in and hopefully now the printer will be able to recognize that cartridges are still not epty, but if still the same thing try to use another colored cartridges if possible so we can check if that will also give the saem results...
Hope that helps.......
I have a Canon printer/scanner MP210. I ran out of black ink, though at the time, the color ink was working perfectly. I replaced the black ink cartridge and the printer now prints in black perfectly. ...
First try a hard reset - Unplug printer from power supply, wait 2 minutes and replug and see. If that doesnt work, try uninstalling and reinstalling the printer driver and software. Also ensure that the cartridge is properly seated in the holder.
Oct 10, 2008 | Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
14 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
