Question about Panasonic PT-47WX42 47" Rear Projection Television
PT-47WX42 47 - Red color becomes prominent and screen goes blank when changing channels
My TV has started to act up lately. It is a Panasonic PT-47WX42 47 and we have had it for 5 yrs. When we turn it on, the red becomes very prominent., and sometimes when changing between channels,(especialy between analog and HDTV channels) the screen goes blank and comes back after a little while. The verizon fios screen menus which are blue, becomes darker and the whole screen is darker. Any help will be great.
    Top Expert:
  • Panasonic Master
  • 76,016 Answers
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Jul 20, 2017
  • 4 Answers
SOURCE: Picture doesn't work..Panasonic 47 inch TV PT-47WX42
Dood, if you really needed a new mother board for your TV the biggest problem on your hands would be finding the replacement.  The motherboard is so easy to remove it would make you laugh.  I think it has four clip bridges and four of five screws.  You seperate the clip bridges, take the screws off and maybe take a picture of the cables so you remember where to plug them in and you're done.  Like I said, take a snap shot so you dont forget where to put your cables back in.
Posted on Oct 24, 2007
Slinteriors
  • 8617 Answers
SOURCE: panasonic pt-53wx53g tries to turn on but goes right off
That is indicating that the convergence circuits have shutdown the set. You will need new Convergence ICs. They should be STK392-110 or STK392-120 either number works the 120 being the better chip. I will post a link where you can get the new ICs and they provide step by step instructions with pics so you can do the repair yourself. You will find your IC numbers under the section titled Convergence ICs just click on that and you will find your STK numbers.
http://servicemanuals.vstore.ca/
Posted on Mar 30, 2008
kevin000
  • 1847 Answers
SOURCE: 1080i
Can you explain the problem in more detail..
Posted on Aug 29, 2008
asnowman
  • 788 Answers
SOURCE: I have a problem with my Tv pt-47wx42
Your symptoms sounds like a damaged convergence IC.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
If your colors line up in the middle of the set and at the top but the picture is concave then you may have a faulty component in the pincushion circuit. When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes. If it is like you described and it is in the top and bottom, you may have a problem in the top and bottom pincushion circuit.
You stated that the charge will be $80.00 to diagnose this problem, I would ask if the diagnostic applies to the repair, if you choose to repair the set.
I have seen this type of repair run from $250.00 - $350.00.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon and it should only add the cost of the part to the repair.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 07, 2009
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Posted on Nov 13, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
The color goes out on my panasonic PT-47WX49E TV.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
May 11, 2012 | Panasonic PT-47WX49 47" Rear Projection...
It will turn on, but as soon as the bulbs light up, the tv will go blank and the red power light will start blinking.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Panasonic PT-47X54 47" Rear Projection...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Blank Screen - Panasonic PT-50LC13-K
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Mar 16, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence issue
You can go back to factory settings by pressing and holding the ACTION and POWER buttons on the TV while it is on. A CHK screen will appear and when it does release the buttons and then power the set off then on again. This had reset all settings back to factory conditions. You will have to reprogram any channels into memory after this.
Mar 29, 2007 | Panasonic PT-51G44 51" Rear Projection...
Pip
On the front of the TV while it is on, press on the ACTION and POWER buttons at the same time and hold them for about 5 seconds until the screen goes blank and comes up with a diagnostic screen. Once that happens release them and press action again to clear the diagnostic information. Now your TV is se back the way it was brand new so you will have to proram the channels back into memory and apply your color,brightness,hue etc..settungs as those have all gone back to factory as well.
Mar 22, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
